Home > Technical (L322) > Brakelights/Switch. L332 TD6 |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
I don't know about your brake switch but the air suspension inactive / hdc / abs lights on usually indicates a low voltage occurrence. Hows your battery? |
19th Feb 2015 9:38pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
Brake light faults on the early cars is usually down to a failing LCM... |
19th Feb 2015 10:26pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Have you fitted any LED's to the vehicle? Land Rover Addict
19th Feb 2015 10:31pm |
Dazzler Member Since: 09 Sep 2013 Location: West Sussex Posts: 34 |
Hi thanks for your reply,Yes the rearlights are Led;s |
19th Feb 2015 10:36pm |
Thanks will check Battery |
19th Feb 2015 10:39pm |
If you have an IID, switch off cold/hot monitoring and it should stop the flash (that's the car checking the lamps if they are filament)
Cool Thankyou |
19th Feb 2015 10:41pm |
Yes they do! Very common LCM's failing and leaving the brake lights permanently on!!! |
19th Feb 2015 10:55pm |
19th Feb 2015 11:04pm |
Hi checked multiplugs sensors all ok. went to LR specialist only thing that came up was Brakelight switich. The new one I fitted was from LR Direct a Brtipart switch. Specialist said get a Genuine one and try that. Done this today and the brakelights stayed on permanently ?? . Put Britpart one back on all fine again.ABS lights hdc/air suspention stayed on with both switches. Could it be the Light Check Module ?. If so where is it Located please. Thankyou Darren. |
26th Feb 2015 9:28pm |
Behind the bonnet pull panel... Black box |
26th Feb 2015 9:37pm |
Cool thankyou. Hope this is what it is. Coz Im pulling my Hair out |
26th Feb 2015 9:43pm |
Evening well Changed LCM fitted new genuine brakelight switch cleared the codes. Hey Presto Air Sus/HDC/ABS All went away. Brakelights working fine. Drove 150 miles all good. Drove 3 miles today to my Shock All back and the Brakelight on permanently , Any Ideas please. |
4th Mar 2015 8:47pm |
Somewhere in my memory bank i remember there being an issue with a loom between the abs ecu and either the lcm or the bcm and JLR suggest you cut a wire from the abs ecu...
4th Mar 2015 11:18pm |
