Home > Technical (L322) > Iid Bt tool
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Iid Bt tool
What can it really do useful that you can't live without and LR should have activated other than experiment playing? I know codes and stuff but have a reader clearer already, ta _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #313611 19th Feb 2015 10:52am
Take a look at GAPs website, all the options that can be changed are there.
It's your call as to whether you can live without, lazy locking, turning TPMS off etc etc etc Got - 2017 SDV8 Autobiography in Loire Blue
Post #313613 19th Feb 2015 10:59am
i've ,
turned rear pdc volume up
switch off key in ignition bong
switch off steering in/out
beep on lock/unlock
switch off cold/hot bulb monitoring [if leds fitted]
switch off tpms
mine had speed autolock on doors, switched that off ... - .- -.
Post #313614 19th Feb 2015 11:01am
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
@Stan - Where did you find the volume control for the PDC..?
Mine could do with going up a notch or two... Ash
2016 SDV8 AB
Post #313618 19th Feb 2015 11:14am
PAM-parking aid menu Ash... ... - .- -.
Post #313620 19th Feb 2015 11:16am
comports
Thumbs Up Ash
2016 SDV8 AB
Post #313621 19th Feb 2015 11:18am
steptoe
I'm not a lard arse and can get in and out with having the steering column doing it's retracting act so i'veswitched off the retractable steering column as i've seen a few posts where the column has got stuck, meaning the car isn't driveable.
Lowered the standard driving height by 15mm.
Done away with the "bong bong bong" warning that the key is in the ignition when the door is open.
Post #313630 19th Feb 2015 11:58am
mjdronfield
Enabled park heat, so I can set the FBH to come on in the morning. Have Aux Heat / Vent on the menu now
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #313714 19th Feb 2015 4:50pm
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Eeeeek! I wonder if this icould be what's stopping my FBH working then ?
Post #313747 19th Feb 2015 6:21pm
comports
That'll be the kiddie then Evro
@Stan - Alas I don;t get the PDC volume when in PAM menu on my 2010 - perhaps it's different now Sad Ash
2016 SDV8 AB
Post #313751 19th Feb 2015 6:45pm
mjdronfield
Mines an early car, so the fbh system may be slightly different activation wise..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #313756 19th Feb 2015 6:59pm
@Ash, is it in the FF's dash menu perhaps.. ... - .- -.
Post #313757 19th Feb 2015 7:02pm
comports
Thx Stan - will have another look
MJ - My 54 would have been the same as yours. I seem to remember you also have to reset the dash to finally enable the menu to appear. Ash
2016 SDV8 AB
Post #313850 19th Feb 2015 10:41pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
RTFM Wink
Says FBH can take up to a week to appear after activation Rolling Eyes Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #313851 19th Feb 2015 10:46pm
comports
Not if you also do the dash reset - it appears straight away then (or did on mine) I was also advised of this by my local LR indy Ash
2016 SDV8 AB
Post #313858 19th Feb 2015 11:11pm
