![]() | Home > Technical (L322) > How do the Adaptive light work? |
Still curious. My pre 2006 4.4V8 Vogue did the whole crosseyed thing, my 2006 4.2 and 2010 5.0 did too. This is 2007MY Vogue with Bi-Xenon lamps, so by law (I understand) it should be applying some sort of self levelling? So surely I should see at *some* point a test that it's working? I'm not interested in AFS tbh, I just want to know if my lamps should swivel up and down at least?
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Yes i believe all AFS models do the test as the ECU is looking for their angles NON AFS i.e. DHL lights don't do the test... I believe |
Cheers, my only concern being that the 4.4 didn't have AFS, but *did* do a light check..... Land Rover Addict
This seems to say DHL (Dynamic Headlight Levelling) and AFS are the same thing?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
2 separate functions but they use the same step motors gary... ... - .- -.
...or not |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6767 ![]() ![]() ![]() |
I have it |
Alanm_3 .... mine's not an SE, just has DHL listed on the build list |
OK been out and checked on a 2006 "55reg" TD6 Vogue WITHOUT AFS and they don't go boss eyed! And i have also checked a 2007 TDV8 Vogue WITHOUT AFS and NO boss eyed again! Checked an 08 VSE and boss eyed |
Cheers Craig |
philbathurst Member Since: 28 Apr 2013 Location: Iver Posts: 139 ![]() ![]() ![]() |
Have read all posts relating to adaptive headlight operation, but not grasping it
