Home > Technical (L322) > How do the Adaptive light work?
Page 3 of 3 <123
DMRR wrote:
Just looked at my build list and see this :
Dynamic Headlamp levelling
....but patently they don't, or is that some other magic?
DHL is Vogue spec and AFS is VSE & AB spec sir... Obviously could be spec'd as an option on all those years Thumbs Up
Post #310596 4th Feb 2015 5:13pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Still curious. My pre 2006 4.4V8 Vogue did the whole crosseyed thing, my 2006 4.2 and 2010 5.0 did too. This is 2007MY Vogue with Bi-Xenon lamps, so by law (I understand) it should be applying some sort of self levelling? So surely I should see at *some* point a test that it's working? I'm not interested in AFS tbh, I just want to know if my lamps should swivel up and down at least?
So - anyone else out there got a TDV8 3.6 with non-moving Bi-Xenon lights on startup? Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #310598 4th Feb 2015 5:14pm
Yes i believe all AFS models do the test as the ECU is looking for their angles NON AFS i.e. DHL lights don't do the test... I believe Confused
Post #310599 4th Feb 2015 5:17pm
DMRR
Cheers, my only concern being that the 4.4 didn't have AFS, but *did* do a light check..... Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #310600 4th Feb 2015 5:22pm
This seems to say DHL (Dynamic Headlight Levelling) and AFS are the same thing?
Post #310609 4th Feb 2015 5:42pm
2 separate functions but they use the same step motors gary... ... - .- -.
Post #310626 4th Feb 2015 6:52pm
DMRR
...or not Sad
Still no wiser - are there no other TDV8 Vogue drivers? Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #310675 4th Feb 2015 9:51pm
I have it Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #310696 4th Feb 2015 10:32pm
DMRR
Alanm_3 .... mine's not an SE, just has DHL listed on the build list Twisted Evil Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #310699 4th Feb 2015 10:37pm
OK been out and checked on a 2006 "55reg" TD6 Vogue WITHOUT AFS and they don't go boss eyed! And i have also checked a 2007 TDV8 Vogue WITHOUT AFS and NO boss eyed again! Checked an 08 VSE and boss eyed Thumbs Up
Not conclusive proof as its just 3 cars but... Whistle
Post #310713 4th Feb 2015 11:42pm
DMRR
Cheers Craig Smile
Wonder why the BMW 4.4 did it then .... hey ho!!! I will assume that I am not causing a problem driving around with my dipped beam on now! Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #310715 4th Feb 2015 11:45pm
Post #310718 4th Feb 2015 11:47pm
philbathurst
United Kingdom 2016 Range Rover Vogue SE TDV6 Montalcino Red
AFS still confused
Have read all posts relating to adaptive headlight operation, but not grasping it
my 2011 tdv8 autobiography build spec states I have Auto High Beam Assist - that works fine
also states i have Dynamic Headlamp levelling & Adaptive Xenon Headlamps - the cornering lights work fine
the headlights appear to be high! not sure what to look for to know that the adaptive / levelling headlights are working
being a little dim I cannot tell if the headlights move when driving
they don't seem to go " boss eyed" when turned on ( is it obvious when this happens ?) - no warning lights on dash when lights turned on
what should I be looking for ? could it be the AFS control module that many are saying they they replaced
Post #316719 7th Mar 2015 2:44pm
Page 3 of 3 <123
