Home > Technical (L322) > New Windscreen Fitted - Auto Wiper Problem
Page 3 of 4 <1234>
OK, brand new LR sensor has just been fitted and the lights and wipers STILL don't Censored work!!!!
Can anyone, please, suggest what else could be wrong?
Thoughts:-
1. 'Hard reset'. i.e. disconnect battery and leave for 15 minutes.
2. Diagnostic tool investigation from dealer when she goes in for a service next week.
Can't think of anything else. Si. <This is my name.
Post #311160 6th Feb 2015 1:55pm
Have they caught/cut a wiring loom somewhere whilst cutting out the old screen?
Post #311162 6th Feb 2015 1:59pm
in all the hassle you've been having i wonder if the connections have come loose somewhere, other than that , check fuses and a battery reset... ... - .- -.
Post #311163 6th Feb 2015 2:00pm
I cannot get anyone to 'admit' to cutting any wiring, so can only assume they've not.
I did a quick check on Google and found the below link which suggests getting a LR 'screen, as has been said many times before. The symptoms are EXACTLY what mine is doing.
http://www.rangerovers.net/forum/6-range-r...del-2.html
I'll see what the specialist says on Tuesday and then present the above link to the windscreen company if they can't find a less invasive cure.
Thanks Craig and Stan. Thumbs Up Bow down Si. <This is my name.
Post #311164 6th Feb 2015 2:04pm
Final update here.
I had a Pilkington windscreen fitted earlier and everything now works perfectly.
The windscreen company still insisted mine was the first RR they've done that needed the OE 'screen.
Thanks again for all your helpful comments. Thumbs Up Si. <This is my name.
Post #313322 17th Feb 2015 7:26pm
Thumbs Up ... - .- -.
Post #313329 17th Feb 2015 8:08pm
Glad its finally sorted sir Thumbs Up Bow down
Post #313344 17th Feb 2015 9:54pm
Autobiography
2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
I had this too...also with National Windscreens.
The glass was poor quality and affecting the rain sensor and the AHBA. Certain VIN numbers will insist on genuine glass for this reason.
Post #313374 18th Feb 2015 5:29am
The irony to all this is I noticed a tiny flaw in the Pilkington 'screen last night on the way home. It's about 1" diameter and on the lower passenger side. The flaw gives a small 's-shaped kink to things in that area.
The previous non-OE screens have been flawless in that regard.
The Auto Windscreens manager has just called me to check all is well and I mentioned it; not through a complaint, but more out of amusement. He's offered to replace this 'screen if I'm not happy, which was very decent of him. I declined. It's taken me three weeks to get everything working and I really don't want the hassle for such little gain. Si. <This is my name.
Post #313386 18th Feb 2015 8:22am
160dmb
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
I had screen replaced about 6 months ago by Autoglass, first fitter on site was very good and careful then a monkey turned up to help him take the old screen out.
They fitted the new one and it looked like a reasonable job but my auto wipers and auto lights didn't work.....
Turned out they had cut the wires in the headlining.
To their credit Autoglass handled it very well and paid my local dealer to repair the wiring which was behind the sunglasses holder in the roof but this just goes to prove that it is possible to cut the wires on the screen removal. 2016 (L405) Autobiography in Black with Ivory - for ULEZ
2014 (L405) VSE in Black with Ivory
2011 (L322) VSE in Black with Ivory
2005 (3.2 V6) Porsche Cayenne in Black with Savanna
1999 (P38) VSE in Burgundy (?) with Sand
Post #313459 18th Feb 2015 3:52pm
pld118
Glad it's sorted Si,
Did you have to point out it should be LR/ Pilkington or was that a natural progression due to the first effort not working?
Post #313464 18th Feb 2015 4:11pm
Ryan, I think we both arrived at the same conclusion.
They first replaced the sensor and when that didn't cure things, and after having two non-OE screens, they couldn't do much else other than go the Pilkington route. Si. <This is my name.
Post #313498 18th Feb 2015 5:37pm
pld118
Thanks Si, it LR and also Pilkington stamped as ours just says Pilkington?
Post #313507 18th Feb 2015 6:16pm
Just Pilkington.
Now for some bad news:
Just spoke to Rovertune (they've got my SC today to fit new fuel senders) and they tell me the interior lights are dead. They 'out of curiosity' spent two hours trying to fix them. They put her in Transport Mode, switched modules and checked fuses, etc. Nothing made any difference. I've not been charged for this, which was rather decent of them.
So.... There's now a high chance the new screen, when fitted, has pinched a wire for the interior lights! So it looks like yet ANOTHER call to Auto Windscreens tomorrow.
Truly and unutterably fed up!! Sad Si. <This is my name.
Post #313512 18th Feb 2015 6:39pm
its uncanny that you and Ryan have the same model and colour and both suffer with 'unusual' problems..
spooky  ... - .- -.
Post #313513 18th Feb 2015 7:09pm
Page 3 of 4 <1234>
