Home > Technical (L322) > New Windscreen Fitted - Auto Wiper Problem |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 |
OK, brand new LR sensor has just been fitted and the lights and wipers STILL don't work!!!!
6th Feb 2015 1:55pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35293 |
in all the hassle you've been having i wonder if the connections have come loose somewhere, other than that , check fuses and a battery reset... ... - .- -.
6th Feb 2015 2:00pm |
I cannot get anyone to 'admit' to cutting any wiring, so can only assume they've not.
6th Feb 2015 2:04pm |
Final update here.
17th Feb 2015 7:26pm |
17th Feb 2015 8:08pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Glad its finally sorted sir |
17th Feb 2015 9:54pm |
Autobiography Member Since: 10 May 2011 Location: UK Posts: 922 |
I had this too...also with National Windscreens.
18th Feb 2015 5:29am |
The irony to all this is I noticed a tiny flaw in the Pilkington 'screen last night on the way home. It's about 1" diameter and on the lower passenger side. The flaw gives a small 's-shaped kink to things in that area.
18th Feb 2015 8:22am |
160dmb Member Since: 16 Dec 2012 Location: Hertfordshire Posts: 455 |
I had screen replaced about 6 months ago by Autoglass, first fitter on site was very good and careful then a monkey turned up to help him take the old screen out.
18th Feb 2015 3:52pm |
Glad it's sorted Si,
18th Feb 2015 4:11pm |
Ryan, I think we both arrived at the same conclusion.
18th Feb 2015 5:37pm |
Thanks Si, it LR and also Pilkington stamped as ours just says Pilkington?
18th Feb 2015 6:16pm |
Just Pilkington.
18th Feb 2015 6:39pm |
its uncanny that you and Ryan have the same model and colour and both suffer with 'unusual' problems..
18th Feb 2015 7:09pm |
