Home > Technical (L322) > Locked out ! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35370 |
the key fob receiver is located at the top of the upper tailgate and uses the rear screen as an antenna so if you do have an unlocking problem then try putting the key fob close to that point..... ... - .- -.
31st Jan 2015 10:52am |
i was searching for something else and came across the possible reason why the OP's key remote didnt work at the petrol station, apparently there appears to be a magnetic field generated by the petrol stations LPG pump's which interferes with the fobs.. ... - .- -.
6th Feb 2015 9:32am |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 |
Thanks Stan, glad I'm not on LPG then
6th Feb 2015 2:10pm |
