Home > Maintenance & Mods (L322) > Broken coolant hose fitting, help identifying part
josh_sheffield
United Kingdom 2011 Range Rover Vogue SE TDV8 Causeway Grey
Hi,
Hopefully someone can help me out. Whilst removing the air intake hose I managed to snap of an adjacent cooling pipe. Mad
Can someone please identify the part number of the fitting in the image with the punch wedged in preventing a coolant escape?
Post #663005 28th Apr 2023 4:24pm
DrRob
Whole top hose assembly. Not available any other way I’m afraid Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #663006 28th Apr 2023 5:58pm
fisha
I’ve seen a thread on here where someone inserted a small length of metal tube to act like a stent. It was epoxied into the large pipe first and then the smaller pipe epoxied onto the bit of metal tube by sliding it over.
You have to go searching for topics using words like coolant, leaks, tdv8, hoses, pipes , stent etc
Edit:
Saved you the bother …
https://www.fullfatrr.com/forum/topic48509.html?highlight=stent V8 or else ...
Post #663016 28th Apr 2023 7:34pm
mjdronfield
As above, can fix it yourself or you need the full assembly and rubber pipes. Not much change from £100 if I remember right.
Hopefully the parts won’t be on back order….
https://www.fullfatrr.com/forum/topic51406.html?highlight=coolant
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #663017 28th Apr 2023 7:43pm
IMHO its quite a risk trying to fix/tap a fitting into the broken pipe... Its not like its an expensive fix compared to an engine Shocked
Post #663037 29th Apr 2023 2:16am
DrRob
I’m with Craig on this… Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #663045 29th Apr 2023 9:26am
JayGee
Given the inherent weakness of the original design and the easily identifiable stress fracture point a good repair with a metal sleeve is likley stronger than OE 2012 TDV8 Vogue (L322)
Post #663048 29th Apr 2023 9:50am
IMHO it is still a ticking time bomb... the plastic has a "life" when it starts to degrade and break at the smallest and most stressed part then it will just keep on deteriorating and break at the next stress point..
I suppose there is an argument for reinforcing a new one to aid it's longevity but that's probably subjective.... Thumbs Up Pete
Post #663052 29th Apr 2023 10:32am
JMC
Spare parts which should be on every 4.4 TDV8 owners shelf:
 The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #663053 29th Apr 2023 11:37am
JayGee
@haylands. Not heard of any other part of that assembly breaking so wouldn’t regard it as a ‘ticking time-bomb’. It’s simply a poorly designed ( Ford) part and should have had a metal reinforcing sleeve or had better stress relief profile in the plastic. 2012 TDV8 Vogue (L322)
Post #663055 29th Apr 2023 12:57pm
If you take a look at the small plastic pipe that leads onto the top of the intake via a clip on connector, much like a diesel fuel connector. And then the same type that run across the top of the radiator to the expansion tank. All of these fail over time so, this side of the coolant system indeed can be a ticking time bomb as Haylands said… Bow down
We change these often when they show weekends with age… Good preventative maintenance in my opinion chaps & chapess’s
Post #663067 29th Apr 2023 7:29pm
JayGee
The engine bay is full of fragile parts just waiting to fail but not all are ‘ticking time bombs’. Infact I think the only genuine items that could be described in such hysterical terms are absent from the 4.4 - crankshafts on the V6 and egr valves on the 3.6 2012 TDV8 Vogue (L322)
Post #663085 29th Apr 2023 11:03pm
So sorry to offend....
I didn't realise ‘ticking time bomb’ was such an hysterical term....
I understood it to mean An item that can, at any moment, fail, resulting in a disastrous outcome.
The failure of the fitting at that point is common enough for it not to be a failure because of heavy handedness in disassembly but deterioration of the plastic under many heat cycles, repairing the first failure and believing the part is now "likely stronger than OE" is, IMHO, creating a "ticking time bomb" with a part whose failure can result in a seized engine.
We shall have to agree to disagree, personally I would fit a new, genuine part... each to their own... Pete
Post #663124 30th Apr 2023 3:15pm
JayGee
I'm not aware of any 'disastrous outcomes' i.e loss of an engine from such a failure. It's a small bore pipe so can't suddenly dump the entire coolant and you would get a low coolant warning and sufficient time to do something about it. Repairing the component with a metal sleeve makes it stronger than the original weak plastic part so I'm again unsure how this becomes a 'ticking time bomb' that can result in a seized engine? 2012 TDV8 Vogue (L322)
Post #663129 30th Apr 2023 5:21pm
andygts
It wouldn't cost that much to have someone knock a complete assembly up out of aluminium. If I'm looking at it right all it needs is a length of pipe approx 2" pipe swaged at both ends and barbed fittings welding on either side.
Find a local custom exhaust fabricator, they usually do custom intercooler stuff aswell, I'd be shocked if you get charged more than than the new part costs and it will outlive the car.
Eg something like this but with another 8mm fitting on the opposite side
https://www.ebay.co.uk/itm/183628653361?ha...R_678q_9YQ Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #663492 5th May 2023 9:15am
