Home > Technical (L322) > Resetting Ignition!!!!!!!!!!
silversurfer
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Orkney Grey
What exactly is meant by "try resetting ignition". To me it means switch of and then on, but the same message re-appears after doing that. Incidentally the battery is charged showing 13.9/14 v. Am I missing something?
Your thoughts appreciated.
Post #306883 21st Jan 2015 8:42pm
Where did you read that and what message are you getting?? Pete
I now have permission from the boss to use Y.O.L.O. Enjoy life
Post #306885 21st Jan 2015 8:46pm
silversurfer
Whilst using diagnostic to read "faults"
Screen reads " Vehicle is not responding to communication attempts .Please try resetting the ignition and check vehicle battery voltage".
I just thought that maybe there was some peculiar procedure re the " RESET IGNITION " BIT
Post #306893 21st Jan 2015 8:53pm
what diagnostic tool are you using?
normally its best to run the engine and then plug in the diagnostic tool.. ... - .- -.
Post #306895 21st Jan 2015 8:55pm
Or its not connected to the OBD2 socket correctly... Thumbs Up
Post #306905 21st Jan 2015 9:10pm
