![]() | Home > Maintenance & Mods (L322) > Off-road height setting |
Mark L Member Since: 29 Oct 2014 Location: Tamworth Posts: 121 ![]() ![]() ![]() |
scwilson Member Since: 15 Dec 2014 Location: Dorset Posts: 240 ![]() ![]() ![]() |
Thanks. Are there any measurements or guides to what they should be for those 3 positions? As in, from ground to wheel arch centre or similar? My off-road height did look somewhat higher than those pics but I could be wrong. I am assuming it's not going to raise it so high that it causes damage? I presume the computer controls that and I would not stabalize if the height was not correct. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8377 ![]() ![]() ![]() |
If you measure from the center of the wheel to the top of the wheel arch...
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
They are on here somewhere, measured from wheel centre to top of wheel arch, have a search shouldn't be to difficult to find.
The system can raise the vehicle too high and damage the airbags and flip the sensors if it goes too mad...
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 ![]() ![]() ![]() |
But with ours and all 02 - 05 can be independently set while 05 on cant. if normal ride height is -10mm than standard, off road and access height will be -10 aswell. ![]() If the IId tool cant fix it.......burn the FF. If the FF cant be fixed......buy a Land Cruiser! If the LC cant be fixed..............................................BUY a horse !! |
What I put was just the standard measurements, as you say you can't adjust the later ones independently but his system could be well out of calibration or someone has been playing before he bought it.... Pete
Thanks Pete. That picture does look similar to mine when raised at full height. Will check some measurements tomorrow. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16312 ![]() ![]() ![]() |
Im not sure if all models can but certainly the later ones can be put into a super extended mode by holding the buttons in a certain sequence... |
Press and hold up whilst pressing the brake pedal for ten seconds if I remember correctly . 2008 MY Supercharged
I wonder if that is what I did yesterday then when it looked almost too high? I did a full test on all 3 settings this morning and all seems OK to me (I think), I took the measurements with the vehicle parked on a flat surface, measuring from the centre of the wheel (Land Rover centre cap) up to the bottom of the centre of the wheel arch, difficult to be completely accurate with a Stanley tape measure and doing by eye of course but here are the measurements ...
Robgosty Member Since: 20 Dec 2013 Location: Manchester Posts: 232 ![]() ![]() ![]() |
This might help, 3rd post down |
Your year doesn't have extended height.... Pete
ok - obviously just me then yesterday.
