![]() | Home > Maintenance & Mods (L322) > Off-road height setting |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8369 ![]() ![]() ![]() |
I wouldn't worry about those heights, it's close enough, they look a bit better sitting lower as well, if you don't do any serious off roading then it won't make any difference...
scwilson Member Since: 15 Dec 2014 Location: Dorset Posts: 240 ![]() ![]() ![]() |
OK - thanks Pete. I do no off road, just want it correct but as you say, nothing to worry about.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
my height specs are pretty close and tbh as long as the front is 1cm higher than the back then it will be ok...dont ask why the front is higher as nobody seems to know |
Thank Stan - good to know.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3658 ![]() ![]() |
The EAS computer is only clever enough to swear at you and tell you it's gone Pete Tong, self diagnostics and error correction is what the stealers were designed to do |
