Home > General > Do you drop the suspension when parked overnight?
Page 4 of 5 <12345>
miggit
Are but you've got a much newer one than my BMW tractor! My pals P38 shoots up quickly too, think that mines just lazy, like the performance Laughing Laughing Yesterday I couldn't spell Engineer... Today I are one!
Post #302810 5th Jan 2015 1:50am
Even with everything working spot on the earlier ones take much longer than the later ones to raise and lower....
I've just got another compressor for mine and am going to set it up to run both to speed it up a bit whilst offroading and needing a quicker response from the system... Pete
Post #302856 5th Jan 2015 1:19pm
scwilson
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Epsom Green
I have a 2003 RR 4.4v8 and it takes ~ 10 seconds or less on any adjustment, assuming I am rolling forward of course ~ 5mph.
I know the previous owner had the compressor replaced 6 months or so ago.
Post #302862 5th Jan 2015 2:10pm
Java Jungle
Monaco 2011 Range Rover Autobiography 4.4 V8 Nara Bronze
miggit wrote:
If I wanted something near the ground I'd have brought a Bentley, it's a 4 x 4, it's supposed to be high, so you can go were others can't! I want to be above the rest of the world and look down on them Twisted Evil
You've got a point... Thumbs Up
JJ
Post #302889 5th Jan 2015 5:18pm
As with anything else the more you use it the quicker it wears out.....
Post #302892 5th Jan 2015 5:25pm
scwilson
or ... the less it is used, the more likely it is to have a problem when it is Laughing
Post #302894 5th Jan 2015 5:28pm
I guess its just another personal preference Smile
Post #302898 5th Jan 2015 5:42pm
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
I use the button on the drivers door and do it as I am going into a parking space. I do it every time I use the car. My wife never does and probably slides off the seat and out the car Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #303057 6th Jan 2015 9:19am
miggit
Bow down Poseidon Pete Bow down hope your well on the road to recovery Thumbs Up
So what are you trying to do? Bunny hop over obsticales Very Happy Yesterday I couldn't spell Engineer... Today I are one!
Post #303080 6th Jan 2015 11:36am
Squirrel
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Galway Green
Mine is always lowered to Access height when I get out, otherwise I can't get back in very easily, being a shortie and not having side steps. Smile
Post #305058 14th Jan 2015 2:42pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Have to lower mine to the bump stops (via IID) to get my mum in! Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #305103 14th Jan 2015 6:11pm
miggit
Bow down Pete Bow down , your twin turbo lift pump idea, how far have you got? I'm interested, because a lot of the time when I'm hitching up to trailers, some nincumepoop has left the front of the unit too high when shunting it about with a forklift, end result jockey wheel wont go low enough Evil or Very Mad So I have to mess about dropping legs and lifting wheels and picking up legs and so on Evil or Very Mad Evil or Very Mad or I go for the high hitch option with the suspension control and Yawn are we there yet? Yawn
When my buddy does it with his P38, it just jumps in to the hitch, like a magnet Shocked I'm soooo envious.
Question, which system runs at the higher pressure, can't remember, but I get the feeling that it's the old one. If so does the newer system use a different valve block with bigger holes, or have a bigger air tank. Got a feeling that the P38 has a bigger air tank, it can't be the pump cos it looks a quite a bit smaller than the one in my boot.
I used the up / down the other day to shunt 4 trailers at our yard, and by trailer 3 I'd run out of air Big Cry , for a horrible moment thought I'd done another pump in, but got back to normal Yawn slow service after a few minutes Embarassed Yesterday I couldn't spell Engineer... Today I are one!
Post #305113 14th Jan 2015 6:58pm
frikkadel
South Africa
Interesting thread, but my question is , will you accelerate the wear on the bellows?
Ok, the pump may wear a bit quicker, but the rubbers, can they handle the up and down daily?
Post #395871 13th Jul 2016 2:37pm
Handle it no problem at all, they spend all their time going up and down a bit when you drive... when they fail they split, they don't wear through so it is a failing in the material, not wearing them out....
I suppose there is an argument that going up and down more will cause the material to fail quicker but I shouldn't think it makes much difference, just do what you want.... all this micro analysing doesn't really help anyone.... Rolling Eyes Pete
Post #395872 13th Jul 2016 2:56pm
ns2015
United Kingdom 2006 Range Rover Vogue TDV8 Stornoway Grey
I always drop the suspension overnight using the drivers window switch panel. Usually works fine although it did lead to an air spring failing one morning!
Post #395889 13th Jul 2016 3:46pm
Page 4 of 5 <12345>
