![]() | Home > Wheels & Tyres > staggered wheels-21" tyre sizes-rolling radius |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35657 ![]() ![]() |
oh dear.......... don't fit them they are incorrect wheels for the FF...
tony66 Member Since: 01 Dec 2014 Location: fife Posts: 92 ![]() ![]() ![]() |
yes-they came off a disco with a dress ...but are they not around same weight?
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
More likely made for an X5 sir... I shouldn't think they would work on any LR |
you may be correct ...they were fitted to a rrs but the rolling radius is fairly different even at a glance-not long sold my x5 too -wonder if he had transfer box issues lol |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3788 ![]() ![]() |
WTF |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
They are of X5 origin, only BMW would be so stupid to fit different sized wheels to a full time 4x4. Having said that the wheels should fit but you'll either have to run X5 tyre sizes, which will be |
as an ex x5 owner i know they run different profiles front and rear on the x5 to keep rolling radius the same on staggered sets...
Are but you could equally sell them off one at a time, for all those careless drivers |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1473 ![]() ![]() |
If someone wants to mod the rr look, then so be it, chill. That being said Tony, there are issues already discussed which do need to be considered seriously when it comes to the rr.
^^ Fitting the same size tyres on different width rims will give you a different rolling radius, typical staggered wheel sets have a lower profile tyre on the rear because its wider. Example sizes ( random fleabay) FRONTS: 275/40x20 -- REARS: 315/35x20.
Agreed. The example size you list seems to match, but if you try and scale up to match the stock diameter of the rr, I found it difficult to get a good matching pair of sizes. It was a while ago now, so there may be different options now. I just remember thinking it would be easiest just to have 4 matching rims. V8 or else ... |
so fitting a 255 50 20 on a 8.5j rim will give a different rolling radius to fitting to a 9.5j rim? me thinks you are mistaken.. ... - .- -. Y. O. L. O. . |
Agreed Stan, but it will make one hell of a difference if you fit a 255 on a 10.5J rim compared with a 8.5J, you will get to the point where the tread is not wide enough for the rim and the tyre walls will taper in to the tread, this will reduce the ratio between the wall and the tread and thus reduce the height. I only know this from shoehorning 145's on my cooper 'S' reverse rims (5J), in my younger days, because the car ate the tyres too quickly and I couldn't afford the 165's it should have had, strange, I could never work out why the tyres never seemed to last on the front |
You can get 275/45/r21 and 315/40/r21 tyres from Continental, as long as you can find a tyre that's 40 mm wider for the rear and 5% less aspect ratio, you should be good. Having said that, it would appear that you've shot yourself in both feet and the gentleman's veg department |
