Home > Wheels & Tyres > staggered wheels-21" tyre sizes-rolling radius
tony66
Scotland 2005 Range Rover HSE Td6 Tonga Green
i just bought a set staggered wheels for my ffrr 2005-they are 10.5" rear et40[21"] and 9" front also et40 -21"
all 4 are currently fitted with 295/35/21 tyres-of which i can maybe scrape a pair to use
what size options are possible or best to use with those widths..i know 21" not overly common to keep rolling radius similar
any pointers?
Post #302103 31st Dec 2014 7:02pm
oh dear.......... don't fit them they are incorrect wheels for the FF...
my advice is to only fit OE wheels as they are capable of taking the FF's weight.. ... - .- -.
Post #302105 31st Dec 2014 7:24pm
tony66
wheels
yes-they came off a disco with a dress ...but are they not around same weight?
is 10.5 " just too wide for the ffrr-i dont mind keeping them stacked up for when a sport crosses my path tbh if they just wont fit-but if they do it would be nice to get them on-advice regarding correct wheel is recieved though...
Post #302106 31st Dec 2014 7:35pm
More likely made for an X5 sir... I shouldn't think they would work on any LR Rolling Eyes
Post #302108 31st Dec 2014 7:45pm
tony66
staggered
you may be correct ...they were fitted to a rrs but the rolling radius is fairly different even at a glance-not long sold my x5 too -wonder if he had transfer box issues lol
Post #302111 31st Dec 2014 7:54pm
Vogue
WTF Shocked in plain English
Staggered wheels belong on a chopper, a 10 yr old BM or a kids toy - ditch them and buy a proper set of RR wheels and all will be good Thumbs Up 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #302153 1st Jan 2015 1:48am
miggit
They are of X5 origin, only BMW would be so stupid to fit different sized wheels to a full time 4x4. Having said that the wheels should fit but you'll either have to run X5 tyre sizes, which will be Shocked Cos they are runflats, or, if they didn't set you back too much and you really like them, you could always flog the 2 bigger rear wheels and buy 2 smaller fronts to make an equal size set Thumbs Up
At 9J width they are only 1/2" wider than the std RR wheels so I can't see that being an issue, the only fly in the ointment would be if they have come off a BMW saloon, and they are not std fitment for a X5 or X6, then I would imagine that the weight handling will be too low. I'm sure than a bit of googlling will find the answers that you need, Good Luck Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #302206 1st Jan 2015 3:50pm
tony66
x5
as an ex x5 owner i know they run different profiles front and rear on the x5 to keep rolling radius the same on staggered sets...
my facelift x5 came with 19" and once i wore the tyres out i fitted a set 20" with new proxes[staggered]
you dont need to use runflats[i had them on an e61 before and am not a fan either]
as it happens have found another set on the web but it would leave me with a set of 4x 10.5" wide wheels-i suppose they would be superb for the modded t5 brigade etc.when weather improves i will try them on for clearance in any case,but i suspect they will be a bit wide at 10.5"
i have accepted they wont go well on the l322 though
Post #302207 1st Jan 2015 4:01pm
miggit
Are but you could equally sell them off one at a time, for all those careless drivers Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #302209 1st Jan 2015 4:18pm
fisha
If someone wants to mod the rr look, then so be it, chill. That being said Tony, there are issues already discussed which do need to be considered seriously when it comes to the rr.
The weight rating of the alloys... The x5 generally has a lower axle load rating, so the wheels are likely to that lower value. It is good practice to ensure that the load rating of the wheels matches or exceeds the axle ratings. That way the wheels can take the weights the car is designed for and are less likely to fail prematurely from being weak. So it's worth trying to check this out. It may well be stamped on the inside of the alloy.
Tyre size is very important. Not so much the overall size that you choose, but that the rolling radius of the front axle matches the rolling radius of the rears. This is (at least on the earlier l322s) due to the centre diff being auto torque biasing based on detecting the difference in the rotation speeds of the front and rear propshafts. If you have different rolling radius on the axles,( something that would be easy to happen with a staggered setup) then the props will always rotate at different speeds, and centre diff tries to fight this constantly ... Result being a knackered diff. The solution is to make the front and rears being within 1% difference of each other ... And even then I would personally try to be less than that as tyre wear rates could take the difference beyond that. I looked at staggered 20" bmw alloys at one point and couldn't get a pair of tyre sizes that came within 1% of each other unless front and rear tyres were the same size ... In which case you may as well have 4 wheels the same. V8 or else ...
Post #302784 5th Jan 2015 12:10am
miggit
^^ Fitting the same size tyres on different width rims will give you a different rolling radius, typical staggered wheel sets have a lower profile tyre on the rear because its wider. Example sizes ( random fleabay) FRONTS: 275/40x20 -- REARS: 315/35x20.
This equates to 40% of 275 = 110 mm x 2 = 220mm = 8.66" + 20" total diameter of front 28.66"
35% of 315 = 110.25 mm x 2 = 220.5 mm = 8.68" + 20" total diameter of rear 28.68"
so there is 0.02" or 0.5 mm difference between front and rear or 0.069 % difference, which in the grand scheme of things is naff all Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #302797 5th Jan 2015 12:47am
fisha
Agreed. The example size you list seems to match, but if you try and scale up to match the stock diameter of the rr, I found it difficult to get a good matching pair of sizes. It was a while ago now, so there may be different options now. I just remember thinking it would be easiest just to have 4 matching rims. V8 or else ...
Post #302816 5th Jan 2015 10:02am
so fitting a 255 50 20 on a 8.5j rim will give a different rolling radius to fitting to a 9.5j rim? me thinks you are mistaken.. ... - .- -.
Post #302817 5th Jan 2015 10:28am
miggit
Agreed Stan, but it will make one hell of a difference if you fit a 255 on a 10.5J rim compared with a 8.5J, you will get to the point where the tread is not wide enough for the rim and the tyre walls will taper in to the tread, this will reduce the ratio between the wall and the tread and thus reduce the height. I only know this from shoehorning 145's on my cooper 'S' reverse rims (5J), in my younger days, because the car ate the tyres too quickly and I couldn't afford the 165's it should have had, strange, I could never work out why the tyres never seemed to last on the front Whistle
Most of the BMW sets seem to have a difference of 2", if you put the same size tread on both, there has got to be a difference in height. Not only will it reduce the height, slightly, it will also expose the rim to more damage from the road and kurbs and anything else that jumps sideways at you Laughing Yesterday I couldn't spell Engineer... Today I are one!
Post #302821 5th Jan 2015 11:05am
miggit
You can get 275/45/r21 and 315/40/r21 tyres from Continental, as long as you can find a tyre that's 40 mm wider for the rear and 5% less aspect ratio, you should be good. Having said that, it would appear that you've shot yourself in both feet and the gentleman's veg department Shocked as there are very few 21" tyres to start with, couldn't you have got them in 20"? It would have made your life a lot easier Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #302825 5th Jan 2015 11:28am
