![]() | Home > Technical (L322) > Dreaded Flat Battery |
Fish Member Since: 30 Aug 2014 Location: Bolton Posts: 301 ![]() ![]() ![]() |
The battery always seems to settle at 12.2v. Could that be the battery that is faulty then.. I've just had it out and it started 3 times no problem. |
Thanks, it's looking more and more likely that a new battery is needed even though this one is less than 12 months old. Before I bought it Geoff had done the alternator, fsr etc.etc. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Did you replace the battery when you replaced the alternator? If the Alternator was spiking then it could have knackered the battery in which case it won't hold charge properly.
I think everything was done at the same time while he was trying to sort the flat battery problem.
I ran the recon cycle overnight and when I checked it this morning while still connected it was showing 13.5v. When I unlocked that dropped to 12.2v.
Based on the readings above I have either got a drain or the battery can't hold full power |
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 454 ![]() ![]() |
Fish: Did you get a new battery in the end, and if so did it cure your problems?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35651 ![]() ![]() |
those voltage figures sound ok Steve.. ... - .- -.
Thanks, Stan. |
I've not sorted mine yet, I've been monitoring it this week. After a few days of short journeys it seemed to settle at 12.2v but this morning was actually 12.1v. I have had a good motorway run today so will check it again tomorrow.
If you've had a decent run on the motorway today your battery should now be reading 12.8-12.9V or even 13V due to surface charge.
Thanks, nicedayforit (that’s a mouthful! (And do you really look like your Avatar?!!!)
Oh, sorry, that last remark by nicedayforit was maybe directed at Fish?
@bebechoon |
