![]() | Home > Maintenance & Mods (L322) > wheel alignment |
Sort of. If they have the old Kwik Fit system it doesn't measure all dimensions, but the later Hunter system does. Bear in mind the vehicle also has to be put into tight tolerance mode before alignment, and that requires diagnostics to enable it. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8747 ![]() ![]() ![]() |
They should be able to toe the fronts correctly but thats Only part of the story. Quite a few quick fits and more f1 auto entree have the hunter Hawkeyes 4 wheel alignment rig. Consists of a dedicated ramp fixed laser post and 4 wheel reflectors. It does a full alignent on the whole car.
