Home > Maintenance & Mods (L322) > changing wather pump fbh
Norway
Norway 2003 Range Rover Vogue Td6 Adriatic Blue
Hi
Does anyeone have some drawings or guiding on how to change the wather pump connected to the fbh.
thx -03V td6
-72 Cadillac Coupe DeVille 7,7liter.
Post #210204 14th Sep 2013 10:14am
it might be worth downloading the RAVE workshop manual ..link in the wiki. ... - .- -.
Post #210206 14th Sep 2013 10:15am
Norway
Hi
Found it all right, but how do i get it detached from the hosing.
And how to air bleed the air/refill the cooling liquid on this system.
thx -03V td6
Post #210217 14th Sep 2013 10:52am
Have a google for webasto thermotop axilliary heater.
Here are a few exploded diagrams for it out there. Rave doesnt cover it too well as LR will opt to reace the whole unit rather than fix it so only removal from the car is covered.
There are a few pumps out there on ebay etc, from memory when i was looking at mine it is a relatively easy job to remove from the fbh. Few screws and a couple of hoses. There is nothing that can't be fixed with a hammer😜😜
Post #210225 14th Sep 2013 11:41am
Norway
Hi
Thx for this.
I got the pumpe from a local dealer, not wery expensive, and its hold tight by a rubber band like ring thats only attach with one screw.
Anyway the gd hoses i cant get off. Is is a type off quick shift system, or do i have to remove a splint. Il post a youtube guide on this when I get i right
Thx -03V td6
Post #210234 14th Sep 2013 12:18pm
http://nbalacrity.co.uk/wp-content/uploads...Boiler.doc
Does that help. Aparently you need a pair of mole grips (locking pliers) to remove the clip as pliers will slip off..... There is nothing that can't be fixed with a hammer😜😜
Post #210235 14th Sep 2013 12:28pm
Norway
Hi
Nice article, but unfortunatly it does not answer my questions.
Take a look at this pictures for the hose connection.
I could naturally just cut the hoses, but i sup there a way around that. Smile
If you take a look at the last picture, it looks like theres a flat pin that could be pulled out. Theres not much to pull with but my guess is that thats what has to be done. -03V td6
Post #210239 14th Sep 2013 1:04pm
ebajema
If you mean the U shaped piece of galvanized wire, then I can say with 99% certainty, yes. If you pull it out in the bend it slides out. Be careful not to drop it, they sometimes come out.
Once you removed this locking feature, the hose comes off after some jiggling. The same water hose connectors are used on the engine and transmission water coolers, that is why i know Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #210242 14th Sep 2013 1:41pm
Yea that is a locking clip.
As ebajema said its a u shaped piece of wire which locks into a groove in the pipe. Should slide out to the left sa per the pic with a screwdriver me thinks. There is nothing that can't be fixed with a hammer😜😜
Post #210246 14th Sep 2013 2:15pm
Norway
Thx, that did it. It came off easily, Assembling is just as easy.
Now, how do I refill the system with coolant? or is it a part off the main cooling system? -03V td6
Post #210281 14th Sep 2013 6:26pm
Norway
Hi
Looks like the fba sircut and the engine coolant circut is connected, so topping up the engine coolant should do the trick.
If anyone dissagrees i appreciate a comment. -03V td6
Post #210902 18th Sep 2013 12:36pm
Its is part of the main coolant circuit so you need to look how to fill and bleed that. There is nothing that can't be fixed with a hammer😜😜
Post #210999 18th Sep 2013 8:49pm
Norway
Hi
Iam about to swap the old Fbh water pump out with a new one due to an error code related to it.
But as I got the inner wheel arch out I came over a switch, the was unused.
What is this fore? 'Anyone plz. Can this be whats giving me the fault code: wather pumpe failure. -03V td6
Post #289580 29th Oct 2014 4:21pm
Norway
 -03V td6
Post #289590 29th Oct 2014 5:16pm
Norway
Ist a god damn strugle to get the FBH out, at least without removing the wheel as sugested. Got to continue tomorrow, then with the wheel off.
Evil or Very Mad -03V td6
Post #289605 29th Oct 2014 7:00pm
