Home > Technical (L322) > Brake Fluid Change |
Gents (&Ladies...)
17th Dec 2014 11:22pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
When replacing all my brake pipes from ABS to wheels, I only used @ 1.5 litres to refill and bleed (quite extensively!) IIRC.
18th Dec 2014 12:10am |
Ahhh so if i nose about in the Faultmate MSV i could probably force the ABS pump to activate and kick in... that might be worth looking into tomorrow then and get it flushed out.. I need to check the parking sensors as well so could get this done easily enough. May just get 2litres then as 5 seems a bit excessive then lol FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
18th Dec 2014 12:16am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
4th Jun 2015 3:12pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
Or DOT 5.1, it's a higher specification - higher temperature resistance. - Usually more expensive, but sometimes you find deals where it's cheaper. |
4th Jun 2015 4:45pm |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1511 |
I have *EDIT*LIES, apparently it's not 5.1!!**- ATE Superblue fluid ready to swap mine when I get round to it.
4th Jun 2015 9:27pm |
mat777 Member Since: 06 Apr 2015 Location: Nantwich/Liverpool Posts: 139 |
Hmm, that sounded intriguing.
4th Jun 2015 10:23pm |
I suppose it depends on what they put in it to make it blue. If it's some ultra toxic chemical, it's more likely the chemical has been banned generally, rather than the brake fluid specifically.
4th Jun 2015 11:10pm |
Gosh you're right. it's gone.
5th Jun 2015 8:41am |
Couldn't you just add black food colouring into the tank before a flush to show when it changes? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
5th Jun 2015 8:56am |
Yes I guess that would work, as any reduction in boiling point would only affect the old defunct fluid.
5th Jun 2015 9:00am |
Simple man = Simple solutions.
5th Jun 2015 9:09am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8207 |
I've always found that the old fluid goes dark anyway so it's easy to tell when the new stuff comes through.... Pete
5th Jun 2015 9:55am |
Shouldn't do, there's no brake fluid check on the MOT other than for leaks. If the tester notices the level is low he or she might give you an advisory. |
5th Jun 2015 11:07am |
