Home > General > diff service price ?
Page 2 of 3 <123>
markcaughey
Scotland 2006 Range Rover Vogue 4.4 V8 Buckingham Blue
iv heard thats not the case with my model and that there is a specific amount Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #299324 16th Dec 2014 4:01pm
I'll have to pass on that, never come across that before Thumbs Up
Post #299336 16th Dec 2014 5:08pm
silversurfer
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Orkney Grey
I checked the owners hand book first ,and then drained the diff oil into a clear jug.
Then measured said amount of new oil ,and pumped it back into the diff.
Post #299363 16th Dec 2014 8:48pm
markcaughey
thanks Mr. Green
how did you find the job ? easy enough to get access to the diffs ? Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #299364 16th Dec 2014 9:09pm
markcaughey
Just had a quick look under the car. The front diff I'd covered by the under trays so I had a look at the rear. I can see the drain plug but can find the fill plug anywhere ? Big Cry Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #299447 17th Dec 2014 12:08pm
from the WM mark.. ... - .- -.
Post #299453 17th Dec 2014 12:20pm
Front diff can be accessed with the under tray still on sir Thumbs Up
Post #299632 18th Dec 2014 10:21am
markcaughey
Think I will order the oil and get my local garage to change it ( on a ramp ) . Craig is the best way to go about putting the right amount of oil in just to measure the amount that comes out ? Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #299643 18th Dec 2014 11:09am
Clean the areas around the plugs then remove filler plug (highest plug) first, remove drain plug (lowest plug) and let the oil drain into a container, basin or whatever you have. replace the drain plug and fill the diff with the appropriate oil until it flows out the filler plug, leave to settle for a few minutes and to allow any excess to drain then replace the filler plug. Job done and should take 15-20 minutes.
This job is easier if the diff oil is warm so take the vehicle for a drive first to heat it up a bit Thumbs Up
Post #299648 18th Dec 2014 11:45am
markcaughey
Thanks. Also how do I know if i have the rear locking diff ? Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #299650 18th Dec 2014 11:52am
Absolutely not Mark... You never know if the last person put the correct amount in!
The diffs take an amount of oil... Not fill till it runs out... So, make sure you measure the amount you put into the diff sir Thumbs Up
Post #299725 18th Dec 2014 7:58pm
markcaughey
That's the thing, I'm having a problem finding out the quantity of oil the diff requires. As mine is the ajv8 4.4 there seems to be less info out there on these as opposed to the 4.2 sc and td v8 . Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #299734 18th Dec 2014 8:23pm
Send Dan a PM with your VIN number Thumbs Up
Post #299735 18th Dec 2014 8:25pm
markcaughey
Cheers mate . Will get that done ASAP Thumbs Up Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #299747 18th Dec 2014 9:10pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
Front Diff: 0.75 litres
Rear Diff: 1.1 litres
That's from Topix for an AJV8 4.4 Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #299750 18th Dec 2014 9:51pm
Page 2 of 3 <123>
