Home > Maintenance & Mods (L322) > 2011 rear light lense
Needle
2003 Range Rover SE Td6 Java Black
Just cracked my rear lense ..booo.... is it possible to buy just the clear lense ? or will the older style light lenses fit if i removed them ?
Post #299061 15th Dec 2014 2:31pm
verydisco
You'll need to get the whole unit, so time to call Dan (price is not as bad as you'd think) or you could have a specialist such as Craig at Cam tech custom modify your lights as they need to be opened anyway.
Only fit 2009 to 2002 lights, others will fit but not power. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #299062 15th Dec 2014 2:36pm
Needle
?? thanks for the prompt reply disco but they are fitted to an older style l322 anyway with resistors etc , was hoping to just purchase a lense ans heat the sealant up .((
Post #299063 15th Dec 2014 2:40pm
verydisco
I see, you could do it as a temporary solution, but these are ultrasonic welded (from 2002 to 2012, no matter the style), so you will never get them back together and you can only split them open by grinding the weld. This would be a butcher job really.
sorry to bring the bad news (£) l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #299066 15th Dec 2014 2:48pm
