![]() | Home > Technical (L322) > Removing side light - wingnut stuck |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35647 ![]() ![]() |
soak in wd40 and if still stuck try undoing with a socket over the whole wingnut.. ... - .- -.
Might be a good idea to hold the stud in some mole grips if you are applying heavy pressure, as it is possible the stud will turn in the sidelight setting. one way to get it out!
