Home > In Car Electronics (L322) > Iphone 6 + AUX & Charging Cable
Mutley
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Hi Guys,
When I bought my RR I was recommended a charging lead & AUX cable so I could play the music in the RR via the iPhone 4s, I have upgraded to the new 6+ & i want the same thing, the cable is all connected together not 2 separate devices
Anyone gone down this route as I have searched the net & come up blank, any ideas much appreciated
Cheers Thumbs Up Mutt
FFRR Black TDV8 Vogue MY08
Post #298387 11th Dec 2014 5:15pm
No idea about the cable, but nice to see you back Mutley. Thumbs Up
Post #298388 11th Dec 2014 5:24pm
no they don't do that cable for a 6 yet, but you can buy an adaptor for the end of your old cable to convert it to the new iPhone connection Thumbs Up
one of these......
eBay Item No. 291316233654 There is nothing that can't be fixed with a hammer😜😜
Post #298398 11th Dec 2014 6:11pm
Mutley
Hi Kurt,
Thank you very kind of you to say Very Happy I will try one of those as the Apple store wants £25 quid, so if it works for a £6 quid then its a no brainer!!!
Cheers chaps Mutt
Post #298548 12th Dec 2014 11:04am
GraemeC
All the new Lightning connector iPods only output a digital audio signal.
Older style iPods with the larger connector used to output an analogue signal
The Apple connector for £25 contains a DAC with converts the digital signal into analogue for use with an older style Apple connector
The £6 version may work to enable charging or data exchange, but I doubt it will work if you a plugging into an older style cable to play audio
Although at £6 may be worth a punt Thumbs Up 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #298562 12th Dec 2014 12:46pm
^^ hence why there are no cheap aux/charger cables about, apple adaptor works fine, but you can get that annoying bong questioning compatability....... There is nothing that can't be fixed with a hammer😜😜
Post #298693 12th Dec 2014 9:58pm
Mutley
Hi All many thanks I bought the Apple store version so really appreciate the feedback on the cheap ones, the one I bought works perfectly so many thanks for the help & pointers in the right direction Mr. Green Mutt
Post #299334 16th Dec 2014 5:49pm
