Home > Technical (L322) > Front left driveshaft failure
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
For some time now I have been getting a bit of noise from the front left of the car and even more when turning tightly so eventually got underneath and found the LH front drive shaft had lots of play, assumed it was a CV joint away.
Car was due MOT anyway so asked them to have a look and replace joint/driveshaft.
Phoned them up to see how things had gone to be told all that was wrong was a worn bush on the rear suspension, asked about the drive shaft and they said nothing reported but they would have another look.
Drive shaft replaced, when I collected the car they said it was not the CV joint but the actual splines on the shaft, they showed me it and there was no drive through the shaft.
I always thought that if a drive shaft went you got no drive at all?
Much quieter and smoother now, funny how you do not notice these things getting worse.
Ian
Post #27987 13th Sep 2010 1:16pm
dan_uk_1984
Re: Front left driveshaft failure
Ian
You have a limited slip (Torsen) center diff so this would have locked and you would have been rear wheel drive only. The driver is supposed to be unaware of it's operation, but although very very smooth when kicking in there is usually a very slight delay before moving off. Although with an Automatic you may not notice this at all I supose..
http://en.wikipedia.org/wiki/Torsen#Notable_Torsen_users
In Ye-Olden-Days you could remove the prop on a Range Rover and just lock the diff and drive on 2wd only. It's common with the Freelander that the center diff seizes, so people just take one of the props off!
Post #27989 13th Sep 2010 4:30pm
IanV8
Thanks dan, I suspect I have done about 10k miles towing with it like that, did suspect it was not as good as it should be towing vans in thick mud last year.
Ian
Post #28009 13th Sep 2010 10:14pm
SteveMFr
Site Sponsor
Common on the P38 too. Viscous goes solidus. Wink
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #28010 13th Sep 2010 10:19pm
EDWARD757
2007 Range Rover Vogue SE TDV8 Java Black
A chap at work has a XC90 and his mechanic asked him whether he was aware he was 2WD. Apparently after about 3yrs old, 60-70% of th XC90s this guy sees are now 2WD as the driveshafts are not made true and as such fail early. Again, no indication to the driver. He did go on to say that if you want a proper 4x4, get a RR as LR have been doing 4WD for many years!
Kind regards,
Ed '96 Volkswagen Polo 1.4CL - SOLD
'00 Audi A3 1.8T - SOLD
'97 Lotus Esprit V8 - SOLD
'03 BMW M3 - SOLD
'93 Range Rover 3.9 Vogue SE - SOLD
'92 Peugeot 205 GRD - DIED
'99 BMW 540i Touring - SOLD
'94 Peugeot 405 GDRT - SOLD
'00 Peugeot 406 HDI estate - 63mpg! - SOLD
'08 Range Rover TDV8 Vogue SE - SOLD
'11 Skoda Fabia Greenline II - 94.2mpg!- SOLD
'07 E61 BMW 530d msport touring - SOLD
‘20 Tesla Model 3 SR+
‘20 Tesla Model 3 Performance
Post #28032 14th Sep 2010 4:37pm
