![]() | Home > Technical (L322) > Issues with MY2010 TDV8 |
Issues related to the turbo's, EGR can crop up. There is a lot on the forum of what can go wrong with these. It is the main reason I ended up with a 5.0 SC, the turbo issues and the fact that I love to have a BIG V8 with supercharger |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8686 ![]() ![]() ![]() |
There are a few common issues to look out for, but some won't be obvious on inspection, notably turbo and egr issues. The other stuff is common to all ffrr, so have a look at the good buyers guides on here. There is nothing that can't be fixed with a hammer😜😜
Bryan N Member Since: 01 Jan 2014 Location: Cambridge Posts: 68 ![]() ![]() ![]() |
Also check that factory recall 'Service Action' Q159 has been accomplished (revised software plus new battery). Otherwise the battery will be flat after two or three of days of non-use! BTDT! |
Lad Member Since: 11 Oct 2014 Location: Blackburn Posts: 284 ![]() ![]() ![]() |
How do you check that that has been carried out |
Dealer service records? Contact LR Customer Service at Whitley to have them check against the VIN?
Look at the battery it should be a Glass Mat Battery (part number starts with AGM) signifying a Glass Mat battery |
Thanks Craig. That prompted me to check the battery on my 2010 TDV8 which supposedly had Q159 factory recall accomplished last year- just in case!!!
Mark L Member Since: 29 Oct 2014 Location: Tamworth Posts: 121 ![]() ![]() ![]() |
Interesting. I'll check mine now. |
Your very welcome sir |
Autobiography Member Since: 10 May 2011 Location: UK Posts: 925 ![]() ![]() |
Put your VIN number in Topix. It will tell you any outstanding campaigns. You don't need a subscription. |
shalz Member Since: 28 Jan 2013 Location: where FFRRs roam free...! Posts: 507 ![]() ![]() ![]() |
A quick related Q - if the Q159 recall has been carried out, does the new battery always have to be an AGM one or can the Bosch S5 110 battery still be used as a replacement? MY11 Vogue 4.4 TDV8 - "African Queen" |
