Home > Technical (L322) > Issues with MY2010 TDV8 |
Issues related to the turbo's, EGR can crop up. There is a lot on the forum of what can go wrong with these. It is the main reason I ended up with a 5.0 SC, the turbo issues and the fact that I love to have a BIG V8 with supercharger MY 2010 5.0 SC Galway green and sand interior!!
20th Nov 2014 2:40pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8512 |
There are a few common issues to look out for, but some won't be obvious on inspection, notably turbo and egr issues. The other stuff is common to all ffrr, so have a look at the good buyers guides on here. There is nothing that can't be fixed with a hammer😜😜
20th Nov 2014 5:41pm |
Bryan N Member Since: 01 Jan 2014 Location: Cambridge Posts: 68 |
Also check that factory recall 'Service Action' Q159 has been accomplished (revised software plus new battery). Otherwise the battery will be flat after two or three of days of non-use! BTDT! |
20th Nov 2014 5:49pm |
Lad Member Since: 11 Oct 2014 Location: Blackburn Posts: 284 |
How do you check that that has been carried out |
21st Nov 2014 12:12am |
Dealer service records? Contact LR Customer Service at Whitley to have them check against the VIN?
21st Nov 2014 1:54pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Look at the battery it should be a Glass Mat Battery (part number starts with AGM) signifying a Glass Mat battery |
21st Nov 2014 2:46pm |
Thanks Craig. That prompted me to check the battery on my 2010 TDV8 which supposedly had Q159 factory recall accomplished last year- just in case!!!
22nd Nov 2014 3:09pm |
Mark L Member Since: 29 Oct 2014 Location: Tamworth Posts: 121 |
Interesting. I'll check mine now. |
22nd Nov 2014 5:51pm |
Your very welcome sir |
22nd Nov 2014 10:22pm |
Autobiography Member Since: 10 May 2011 Location: UK Posts: 922 |
Put your VIN number in Topix. It will tell you any outstanding campaigns. You don't need a subscription. |
23rd Nov 2014 9:28pm |
shalz Member Since: 28 Jan 2013 Location: where FFRRs roam free...! Posts: 503 |
A quick related Q - if the Q159 recall has been carried out, does the new battery always have to be an AGM one or can the Bosch S5 110 battery still be used as a replacement? MY11 Vogue 4.4 TDV8 - "African Queen" |
15th Dec 2014 9:45am |
