![]() | Home > Technical (L322) > Which remote do I need for FBH on a 55 plate car.. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8672 ![]() ![]() ![]() |
Afaik, the t91 is the later remote, and is the one I have on the disco4, my ffrr is earlier and has a t90. It's the larger one more triangular in shape than the 91, which is small and oval. There is nothing that can't be fixed with a hammer😜😜
JPS Member Since: 10 Sep 2012 Location: South East England Posts: 565 ![]() ![]() |
Thanks for clearing that up mate, so a later t91 remote wouldn't work on my car? |
Not sure, to be honest. I didn't try syncing the t91 with the Ffrr. The reciever for the disco is labeled t91r though so maybe they are matched.
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
The T91 oval remote should work on your FF, being a 55plate model (with the touchscreen satnav system, I presume).
http://www.webasto.com/fileadmin/webasto_f...rt-t91.pdf
Thanks guys, I think I will take a punt for the T91 remote as there only £30 brand new on eBay, yes my car has the touchscreen nav and is a facelift model. Will let you know the outcome and thanks for the instructions these will come in handy |
stcstc31 Member Since: 01 Jul 2014 Location: dublin Posts: 209 ![]() ![]() ![]() |
the the remote an option or should they work with all cars? |
As above, the T91 like i sell should be perfectly fine |
Thanks mate, do you sell them on ebay? ![]() |
All doozel FFs (TD6, TDV8, etc.) have the FBH fitted as standard and could be fitted to the petrol models as an option, but I'm not sure if all doozel model variants have the remote receiver fitted as standard. Easy way to check is to look in the right rear loadspace bay, if there's a receiver fitted behind the fuse panel then you should be able to get a remote to operate it. |
ah ok cool. thanks |
Not all variants have the remote reciever, so double check. Just seen another post by noddy, which says the t60 reciever will not pair with the t91 so check which version you have. There is nothing that can't be fixed with a hammer😜😜
Received the T91 remote today and programmed it very easily and now works a treat. Just need the temp to drop below 5 degrees now |
