Home > Technical (L322) > Which remote do I need for FBH on a 55 plate car.. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8662 |
Heater should fire up below 16deg on the fob👍
18th Nov 2014 8:30pm |
JPS Member Since: 10 Sep 2012 Location: South East England Posts: 565 |
I thought it was below 5deg? If I hold the left button on the remote the air circulation comes on. To get the heater to activate should I press the right hand button? |
18th Nov 2014 8:39pm |
I read online that you should only use the heater for the length of the journey you are going to do. So a ten mile journey then the heater for 10min before hand |
18th Nov 2014 8:40pm |
Have a read of the remote instructions, there are 2 modes on the remote, ventillation and heat, I don't know if these are individually selectable on the ff.
18th Nov 2014 8:48pm |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
It's not so much how long you have the heater on before making a journey, but making sure your battery is in good condition and gets a good recharge after using the FBH.
18th Nov 2014 8:55pm |
The T91 remote has two buttons, the left button switches the heating/ventilation 'ON' the right button swiches it 'OFF' There is also the following with my T91 fob:- If the temp is low enough and you press the 'ON' button the light on the fob glows red to show the FBH and fan has started. If the temp is high enough and you press the 'ON' button then the fob light will turn green and only the fans will start to cool the interior. Not sure at what exact temp these two functions operate at though. |
18th Nov 2014 9:05pm |
Ok thanks that makes it a bit clearer. When pressing the on button I'm only getting a green light the system comes on but is just the fans with no heat. I'll give it another try in the morning incase it isn't cold enough. |
18th Nov 2014 9:19pm |
18th Nov 2014 9:23pm |
Well it seems it's all working great. I switched the system on about 20min ago to test it (thought it was just the fans) went outside just heard a clicking from the back of the car and opened her up and was lovely and warm inside. Actually sat it there for a few minutes as was warmer than in the house |
18th Nov 2014 9:31pm |
Good to hear, you're cooking on doozel now!! |
18th Nov 2014 9:33pm |
Yep that's working then👍
18th Nov 2014 9:43pm |
Thanks guys will deffinatley come in handy this winter. Have just fitted a new bosch battery also so hopefully that will help |
19th Nov 2014 8:00am |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 |
Grrrrrr!
19th Nov 2014 7:06pm |
