![]() | Home > Technical (L322) > Air suspension ride height has A mind of its own l322 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8541 ![]() ![]() ![]() |
The IID tool from Gap (site sponsors) will calibrate and sort faults with the suspension, I wouldn't think yours is a calibration issue though, the tool will show all faults stored... check the battery voltage first... Pete
normalrangerover Member Since: 23 Mar 2014 Location: Sligo Posts: 21 ![]() ![]() |
Thank you Haylands, I can read the faults with my current module and the faults, What should they be reading and if they are wrong what does this mean? thanks again |
What faults is it showing?? Pete
I think its showing this Articulation Validity Fault |
That is usually a problem with a height sensor, the front ones can flip over and will give an incorrect reading, the computer knows this is wrong as it's so far out, that it gives this fault...
Thanks for your advice. Would it never be effected by the rear, I changed the rear height sensor on the drivers side today, its causing the rear driver side to go very high, (too high) |
Could be, check it looks the same as the other side.... Pete
No doubt you have read this thread:
Thank everyone also for there replys, Also when removing the the rear driver side height sensor was a very hard task, As one of the bolts was baldy damaged, It took a long time to remove using hammers saws, etc, I am just wondering would this effect the read height for the new height sensor, It does not look like its put in wrong but could it be? It looks perfect, |
Also I just did some more research my front left hand height sensor is reading 42.0.v All the other are around 2.0 v also The rear right hand height sensor is reading -42.00 m Even though it is very high on the airbag, What does this mean? Should I Recalibrate the heights? thanks again for everyones help |
