Home > Technical (L322) > Immobilised after replacing relay - Help
CBH25
Australia 2003 Range Rover Vogue 4.4 V8 Santorini Black
Been trying to get my horn to work for ages, so pulled the glovebox out to change the relay.
Left the negative terminal off overnight while doing the work.
Put it back together thismorning and the barrel turns but no engine cranking. Also the AC doesnt work.
The key doesn't make the little click (unlock) noise when you put it in either.
Everything else works fine (radio, Sat Nav, lights etc).
Gap IID doesn't report any obvious faults other than "Power On reset".
Tried clearing everything a\with no luck.
Any ideas please?
Can the GAP IID re-tune my keyFob to the car?
Thanks L322 4.4 Vogue MY03 - Her name is Bulletproof .... you already know she's not Smile
L322 4.4 Vogue MY05 - Sold to my brother
P38 4.6 HSE MY97 - Regretfully sold
Post #288491 24th Oct 2014 1:07am
re-check the battery connection and the voltage state of it as well.. ... - .- -.
Post #288531 24th Oct 2014 8:32am
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
I am sure you have checked all fuses - but just thought I would mention it Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #288537 24th Oct 2014 8:56am
CBH25
Thanks for taking the time to help.
After spending another 6 hours, taking the globe box back out to put the original relay back in, I found a small connection near the relay which was not seated properly.....
After pulling the battery out to get to the start motor relay.
After charging the battery all day out of the car.
After painstakingly checking each bloody fuse.
These beasts are a labour of love! L322 4.4 Vogue MY03 - Her name is Bulletproof .... you already know she's not Smile
Post #288559 24th Oct 2014 9:42am
SMUTT
Really pleased you managed to locate the fault. At least it did not cost a fortune.
Whats not to like - 6 hours spent with the love of your life.
And look at how much more you now know about your car - bet you love it really.
And you have decent weather over there to find the fault in - raining and cold here now. Howard
Post #288564 24th Oct 2014 9:53am
mjdronfield
Well, you won't make that mistake again, should you have to work in that area........
So all positive.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #288630 24th Oct 2014 1:57pm
