Home > Technical (L322) > Range rover l322 td6 2003 front van not working at all
normalrangerover
Ireland
I have a range rover 3.0 td6 vogue, The front ventilation van is not working at all! although all the lights do light up to say it is working, The fault reader cannot find any faults., The rear van is working perfect. What does this mean? thanks
Post #287932 21st Oct 2014 12:52pm
mjdronfield
I'd say changing the final stage resistor (FSR) behind the console should be your first point of call. Causes lots of fan issues and is a common failure point.
Not too expensive and easy to change yourself.
http://www.fullfatrr.com/forum/topic781.ht...eplacement
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #287943 21st Oct 2014 1:24pm
Also, check the language settings on your keyboard as 'f' seems to be coming up as 'v'. Wink
Post #287951 21st Oct 2014 2:09pm
sounds like your VSR is vucked...... Mr. Green ... - .- -.
Post #287958 21st Oct 2014 2:40pm
Fery likely Stan. Vucked in the fagina.
Post #287959 21st Oct 2014 2:50pm
Kurt just made my day Laughing
but definitely going to be the FSR unless the fan is dead.
Forum posts on replacing both items abound, but a good one on getting the fan out - the quick way! .
Post #287972 21st Oct 2014 3:27pm
