Home > Wheels & Tyres > Rear wheels out of alignment scrubbing inside if rear tyres
philmc79
United Kingdom 2008 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
I recently had my FFRR MOT done and to my horror they told me that the rear tyres where down to the cord on the inside and duly showed me, the tyres had only done 8000 miles and scrubbed to useless now, the garage told me i should get new one's fitted and get the 4 wheel alignment checked, this was done and the garage informed me who did the alignment that there was not enough adjustment to get it to Spec, we had a good look round and could not see and bent or damaged components on the rear of the car it does not seem to have any accident damage either on the rear end, has anyone got any idea's where to go to next with this problem, before buying the car 12 months ago it was HPI checked and came back clear so there has not been any reported damage to the car
Hope someone has some idea where to look next
Post #286586 15th Oct 2014 1:24pm
i'd be tempted to go and get the alignment checked at another garage or tyre dealer and get a second opinion and i'd not mention what you have been told at the first garage .... ... - .- -.
Post #286587 15th Oct 2014 1:33pm
Sandyt
As Stan says I would find another place to have the four wheel alignment checked try and find somewhere that uses Hunters kit as I am led to believe it is more accurate Thumbs Up
Post #286599 15th Oct 2014 2:13pm
mjdronfield
Rear hub bushes. Not had the issue myself, but it causes what you have when they are worn.
The wheels move out of alignment when driving.
That said, you should be able to get it in alignment before you start, unless they are totally shot, but the garage should be able to see that..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #286617 15th Oct 2014 4:18pm
philmc79
I have just got the paper work back from the garage that did the tracking and the rear off side can not be adjusted to well within the spec it is -0 45 Toe and can not be adjusted to within spec of 0 04 so something is stopping it from being adjusted have you any idea's all other measurements have been adjusted to within spec, should i have the garage take the whole of the rear off side suspension apart please let me know what you think?
Post #286625 15th Oct 2014 4:31pm
Possibly the top hub joints have a lot of play, which would cause the scrubbing,there is not a lot of adjustment in them in any case, its not like toe on the front wheels, it adjusts on a an eccentric bolt which can be a pain to adjust. There is nothing that can't be fixed with a hammer😜😜
Post #286644 15th Oct 2014 5:04pm
As Mark says it will be the top or bottom hub bushes/rose joints, they can be fairly worn before they start knocking, after I did mine it only just got to spec on the alignment at max adjustment... get the garage to check them for you, they aren't a lot of money and are straightforward to fit Pete
Post #286679 15th Oct 2014 6:58pm
steve9bug
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Check to see if its been jacked up in wrong place and bent a trailing arm
Post #286911 16th Oct 2014 6:59pm
Hasn't got trailing arms, just big wishbones and a toe control arm and I don't think you could jack it up on that.... Pete
Post #286938 16th Oct 2014 8:13pm
If it's inner edge my money would be on the top hub rose joint, coz that would be the way that the camber would be out on a loaded tyre, top pushed in. There is nothing that can't be fixed with a hammer😜😜
Post #286949 16th Oct 2014 8:54pm
philmc79
got it fixed
Got the alignment fixed, had my mechanic strip the rear suspension down, while he did the disks, pads and hand brake, changed all the bushes for neoprene one's and put it all back together took it for a realignment again and all came out well this time, £460 lighter for the tyres and £400 for the labour, disks, pads and shoes but its all working well now, lol, time to move on to the gearbox oils and pan change and the engine oil and filters next, will i ever stop spending ???? thanks you guys for your input they all helped.
Post #287974 21st Oct 2014 3:36pm
Sandyt
Brilliant well done glad it is all sorted as for spending well if you have stopped check you haven't died and gone to heaven Rolling with laughter Rolling with laughter
Post #287995 21st Oct 2014 5:57pm
