Home > Maintenance & Mods (L322) > And now for something completel different |
The IID will tell you what the E-Diff is doing and the percentage of lock applied , Torque applied , over temperature events in various parts , clutch plate wear , open diff override and many others . 2008 MY Supercharged
15th Oct 2014 12:38am |
Don't know I have petrol but my guess would be only the fuel rail hp pump
15th Oct 2014 5:55am |
Dijit Member Since: 09 Jul 2012 Location: Glasgow Posts: 165 |
Yup found it in the manual this morning. Lets see how it works in practise! Rehab is for quitters!!!
15th Oct 2014 9:38am |
On a Discovery 3 A Brake Light Bulb or Faulty Brake Pedal Sensor can cause all these dashboard faults.
15th Oct 2014 10:04am |
The brake lights were my first port of call. I've seen other references to the brake light switches of which I believe there are two switches at the pedal. I've also been referred to the engine compartment wiring loom.
15th Oct 2014 10:13am |
On the D3 its a single Brake Light Switch just above the brake pedal. I also replaced this as they can REEK HAVOC when faulty.
15th Oct 2014 10:15am |
Sounds ominous! Any chance of a link please? Rehab is for quitters!!!
15th Oct 2014 10:29am |
15th Oct 2014 10:40am |
Thanks Gazellio. Rehab is for quitters!!!
15th Oct 2014 11:19am |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
Sorry, been busy. As others have said, the IIDTOOL should be able to do it. That's your best bet. Also, it is one of the checks that the car does on startup. So no errors on startup and you're probably good. I think triggering a situation where diff lock is required will also do it, but is a lot harder in practice. I got the error once on a JLR track during a full cross axel obstacle. (Mine you, with the centre diff fine, the car's progress wasn't hurt. ) if you have easy access to a but if off-road course, that's certainly the most fun way to test it. |
17th Oct 2014 12:34am |
