![]() | Home > Maintenance & Mods (L322) > And now for something completel different |
The IID will tell you what the E-Diff is doing and the percentage of lock applied , Torque applied , over temperature events in various parts , clutch plate wear , open diff override and many others . 2008 MY Supercharged
Don't know I have petrol but my guess would be only the fuel rail hp pump
Dijit Member Since: 09 Jul 2012 Location: Glasgow Posts: 165 ![]() ![]() ![]() |
Yup found it in the manual this morning. Lets see how it works in practise! |
On a Discovery 3 A Brake Light Bulb or Faulty Brake Pedal Sensor can cause all these dashboard faults.
The brake lights were my first port of call. I've seen other references to the brake light switches of which I believe there are two switches at the pedal. I've also been referred to the engine compartment wiring loom.
On the D3 its a single Brake Light Switch just above the brake pedal. I also replaced this as they can REEK HAVOC when faulty.
Sounds ominous! Any chance of a link please? Rehab is for quitters!!!
Thanks Gazellio. Rehab is for quitters!!!
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
Sorry, been busy. As others have said, the IIDTOOL should be able to do it. That's your best bet. Also, it is one of the checks that the car does on startup. So no errors on startup and you're probably good. ![]() I think triggering a situation where diff lock is required will also do it, but is a lot harder in practice. I got the error once on a JLR track during a full cross axel obstacle. (Mine you, with the centre diff fine, the car's progress wasn't hurt. ![]() ![]() |
