Home > Maintenance & Mods (L322) > Anyone recognise this noise
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
When I said it sounds like a cat, I meant like it was a cat (meow type) Very Happy stuck under the bonnet!
Sorry Crying or Very sad
Post #284147 2nd Oct 2014 9:00pm
Laughing Laughing Rolling with laughter Rolling with laughter Thumbs Up Pete
Post #284161 2nd Oct 2014 9:42pm
PaulTyrer
Just my weird sense of humour! Minfd you, after having owned five Range Rovers Fromm the classic (3.5 & 2 3.9's) and a 4.6 P38, you have to have a sense of humour! Rolling with laughter
Post #284167 2nd Oct 2014 9:52pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
If you decide to rebuild I have a voltage regulator going spare for £25 (what it cost me).
Bearings can only be a few quid and diodes aren't more (think £5 each the last time I searched for them).
So in theroy you can rebuild it yourself for about £60.
Post #284196 3rd Oct 2014 12:26am
Thanks for the offer of the bits....
Got to take a look this afternoon after it stopped chucking it down for a while, turns out it's the air con compressor belt tensioner, the bearing has run dry, worn out and it has a fare amount of play in it...
Will get a new one from Dan tomorrow....
I took off the two that tension the main belt, stripped them down and repacked them with grease, hopefully make them last a bit longer... Pete
Post #284692 6th Oct 2014 8:33pm
mjdronfield
That's good news.
We were pretty close then, knew it was bearing noise.
Probably the cheaper failure option !
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #284701 6th Oct 2014 9:11pm
Think I had belt tensioner........
10 points to me!...... Whistle There is nothing that can't be fixed with a hammer😜😜
Post #284777 7th Oct 2014 7:33am
Well done, go to the top of the class.... Thumbs Up
Just to finish this off....
Range Rover want about £80 for the aircon pulley and tensioner as it comes in one piece, it's the same price as the double pulley version for the main drive belt...
There are just pulleys on ebay, mostly listed under BMW for about £30...
I got a new main belt tensioner from a local motor factors (I do get trade discount) for £38incvat, (a bargain, I thought) the plan was to just use one pulley on the air con, all three pulleys are the same...
Anyway, when it turned up it was the same make as the original, an F-Gen, so as the pulleys on the old main belt tensioner were OK I used one of them on the air con and fitted the entire new tensioner on the main belt...
All nice and quiet again Very Happy
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #285232 9th Oct 2014 12:47pm
mjdronfield
Excellent.
Now you just need to post a link up to a video without the bearing noise, and we can all go "V8 !"
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #285242 9th Oct 2014 1:04pm
