It really depends on how much you want to spend, and which arm has the play, oem arms are fairly cheap and easy to come by, from around £60 per side, either from dan, at factors or lrdirect, and any local mechanic worth their spanners should be able to change it. Would do both sides to match up, though not strictly neccessary, is better practice.
The thing to watch for is that the nuts Shouldnt be tightened up before the car is resting on its wheels, if they at then it twists the bushes and they won't last 12 months! There is nothing that can't be fixed with a hammer😜😜
