Home > Maintenance & Mods (L322) > Mot failure
Squaresausage
Scotland 2003 Range Rover Westminster 4.4 V8 Baltic Blue
Mot failure
My Ffrr has just failed its mot on off side arm has excessive play in the pin / bush (2.4.g.2). National tyres said they won't touch it to repair due to the air suspension ?!?. How much to repair this fault and should I do all the bushes while I'm at it?? Poly or rubber?
Also got an advisory on an oil leak.
Cheers What has fallen off today:-)
Post #283528 29th Sep 2014 12:38pm
It really depends on how much you want to spend, and which arm has the play, oem arms are fairly cheap and easy to come by, from around £60 per side, either from dan, at factors or lrdirect, and any local mechanic worth their spanners should be able to change it. Would do both sides to match up, though not strictly neccessary, is better practice.
The thing to watch for is that the nuts Shouldnt be tightened up before the car is resting on its wheels, if they at then it twists the bushes and they won't last 12 months! There is nothing that can't be fixed with a hammer😜😜
Post #283530 29th Sep 2014 12:45pm
Squaresausage
Cheers,
Just got to get the oil leak sorted, and the rust and the coolant leak and the............ What has fallen off today:-)
Post #283540 29th Sep 2014 1:22pm
