Home > Maintenance & Mods (L322) > Help!..Trolley jack jacking points? |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
Cant they be locked in the open position to give access to the jacking points??..cr design if not ! GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
20th Sep 2014 11:37am |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 |
Agreed Paul,
20th Sep 2014 11:41am |
Read here matey>>
20th Sep 2014 11:42am |
Thanks Paul, ....again
20th Sep 2014 11:54am |
Theres a diagram half way down
20th Sep 2014 12:06pm |
Haha, I think the threat of death is a bit harsh because I didn't use the search option mate, but thanks anyway |
20th Sep 2014 12:28pm |
20th Sep 2014 12:35pm |
Ok, I've locked out the 'Deplorable' steps but the standard jack will still not fit in its correct cup
20th Sep 2014 12:39pm |
Never had a problem jacking up under the lower wishbone arm at the rear, spread the load with a suitable wood block. This OK if just changing a wheel, as you aren't "going under" and you can always put a safety stand under your jacking point if needs be. .
20th Sep 2014 1:56pm |
Thanks Joe,
20th Sep 2014 2:27pm |
