Home > Maintenance & Mods (L322) > Help!..Trolley jack jacking points?
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Help!
Got a flat rear tyre, anyone tell me the best place under the car to use a trolley jack?
I have the deployable steps and book say these need to be removed to jack the car up using the normal jacking points
Post #281982 20th Sep 2014 11:16am
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Cant they be locked in the open position to give access to the jacking points??..cr Censored design if not ! GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #281987 20th Sep 2014 11:37am
J evro
Agreed Paul,
Just going by what I remember from reading , also do I need to put it in off roD mode or something?
Post #281988 20th Sep 2014 11:41am
paulmoran2
Read here matey>>
http://www.fullfatrr.com/forum/topic24098.html?highlight=steps GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #281989 20th Sep 2014 11:42am
J evro
Thanks Paul, ....again Thumbs Up
Anyone have any pictures of exactly where I need to place the jack ........I'm still a very nervous first time RR owner without a clue Embarassed
Post #281990 20th Sep 2014 11:54am
paulmoran2
Theres a diagram half way down
The "search" facility is pretty good on this forum, once you use it a few times Jevro Whistle
Alternatively, get a pro / the AA/RAC out if you have any doubts..You can do damage, or just die if you're under and you've done it wrong..
http://www.fullfatrr.com/forum/topic10778....ing+points GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #281992 20th Sep 2014 12:06pm
J evro
Haha, I think the threat of death is a bit harsh because I didn't use the search option mate, but thanks anyway Thumbs Up
Post #281993 20th Sep 2014 12:28pm
paulmoran2
Rolling with laughter Thumbs Up GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #281994 20th Sep 2014 12:35pm
J evro
Ok, I've locked out the 'Deplorable' steps but the standard jack will still not fit in its correct cup
Looks like trolley style lift ...
I can't believe I'm asking how to change a Censored wheel .....all time low Embarassed
Post #281995 20th Sep 2014 12:39pm
Never had a problem jacking up under the lower wishbone arm at the rear, spread the load with a suitable wood block. This OK if just changing a wheel, as you aren't "going under" and you can always put a safety stand under your jacking point if needs be. .
Post #281999 20th Sep 2014 1:56pm
J evro
Thanks Joe,
All done now Thumbs Up
Think my best route is to gets bottle jack if I keep the 'Deplorable' steps so I can at least carry it with me for emergencies etc....presume it would need to be a big one though or use adequate wood packing as she did lift some before the wheel came off the floor any ideas ?.
Post #282000 20th Sep 2014 2:27pm
