![]() | Home > Maintenance & Mods (L322) > Towbar |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2588 ![]() ![]() ![]() |
[quote] Being such a big and powerful vehicle there is a risk that pervious owners could have done a lot of heavy towing
Beau Member Since: 12 Jul 2014 Location: Dorset Posts: 53 ![]() ![]() ![]() |
Agreed Graham. Mine spent most of it's life on the Isle of Wight and there are a lot of pervs with boats there - if it had a tow bar I think it would have been dipping in and out of the salty stuff all the time. ![]() Dolphinboy - thanks for the PM. I've looked a bit more on PF Jones and they also have this which is cheaper http://www.pfjones.co.uk/range-rover-2005-flange-tow-bar-1.html ...they describe it as a Westfalia OEM Flange Tow Bar (stop sniggering at the back) I'll call them tomorrow but anyone know if / why this is worse? Presumably it is still detachable from the armature? And in many ways I'd prefer a height adjustable one (always had them on the Defender). Thanks Beau |
GrahamCharlton Member Since: 17 Aug 2014 Location: Newcastle upon Tyne Posts: 30 ![]() ![]() ![]() |
That's the one I've just bought although I haven't fitted it yet. It looks a really good quality piece of kit. The only thing I have read is that the hitch is prone to rattle or knock slightly as it is located with a removable pin rather than being nipped in with a bolt. Personally I don't think this will be a problem as whatever you are towing is often noisy and rattley anyway. I picked the flange type as it is more versatile with the standard 2 bolt tow ball which will make things like bike racks etc easier to fit. It also looks neater when removed as the whole thing comes off whereas the removable swan neck type still has an ugly great fitting that sits under the bumper |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
I think the only reason to go for a swan neck over flange is some think it looks nicer and it fits into the cubby box next to the spare wheel. It you want a bike rack the flange is the best option. The have been issues with the Swan neck one getting worn out and breaking. Some also say it's quicker to install but the flange is held in by a bolt and R clip so can't really be any quicker.
Thanks - think I'll go for the flange then.
The one I have has a bracket that fits between the ball and the flange. You then just slot the rack into that bracket and it's held in place with a pin. You can just pull the pin out and the rack complete with bikes hinges down and lies on the floor which allows you to open the tailgate. I got it from Halfords a few years ago and I'm sure it was only about £50 or so |
Thanks Graham - sounds good. |
Same as mine. Got a maxxraxx off a forum member and that has a bracket between tow ball and flange. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3895 ![]() ![]() ![]() |
http://www.pfjones.co.uk/range-rover-2005-flange-towbar.html
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
PF Jones is the place to go, and westfalia are the OEM for land rover, if you want to save more dosh, and future proof yourself, get the 13pin westfalia wiring kit, but add it on from the main page I think its under accessories, don't add it to the tow bar on the tow bar page. There's about £20 difference!
I couldn't agree more about the 13 pin electrics. Even if you only tow a standard trailer rather than a caravan and don't need the full functionality of the 13 pins the plug and socket are far superior to the 12N & 12S. They have a thread on them so you just twist the plug and it pulls itself into or out of the socket. I just carry an adapter with me in case I have to tow something without a 13 pin plug. |
Right I have just looked it all up and the savings are greater than claimed!!!!!!!!!
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
++1 on 13 pin over 12n and s! There is nothing that can't be fixed with a hammer😜😜
that is not a fleabay item number I didn't type that honest
