Home > Maintenance & Mods (L322) > What's your favourite mod or refurb?
Page 2 of 3 <123>
Supercharger upgrade on mine. Completely transformed the bottom end.
It's by far my most favourite of any FF modification.
Silver sterring wheel spokes lift the interior nicely. It's my most favourite aesthetic interior modification. Si. <This is my name.
Post #278235 30th Aug 2014 8:36pm
pld118
Exhaust back box DIY rattle can re-spray to banish the obligatory worn off black finish is a subtly good one too... As is some tlc on neglected chrome finish tailpipe tips Thumbs Up
Post #278239 30th Aug 2014 8:47pm
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
So reading thus am I right in thinking that it's possible to bring all the ride heights down? Ie normal road driving, motorway and access height?
Post #278358 31st Aug 2014 7:32pm
to save this thread going off topic ,have a read here andy,
http://www.fullfatrr.com/forum/topic23917....de+heights ... - .- -.
Post #278360 31st Aug 2014 7:41pm
andyleeds
Cheers Stan!
Post #278368 31st Aug 2014 8:23pm
pld118
Stop rear arch rot!
A major L322 bug bear seems to be rear arch corrosion.
Well, a tub of Comma grease (£6.99 Halfords); and rear arch (non metallic ingredient) rubber/ plastic strips, cut to size by you for approx a fiver can - if you, beforehand, clean and prep the rear arches properly and spend an hour or so taking care to do the job right - stop your arches from rusting/ corroding!
*The* best cosmetic preventative piece of maintenance/ refurb that I've learned about on this forum and which - if your rear arches are not yet 'gripped' by this affliction - should avoid costly and/ or time consuming rear arch repairs (the 'upgraded' strips referred to, replace the original - metal in the ingredients - rubber rear arch strips).
How to on this linked threat:
http://www.fullfatrr.com/forum/topic22530....mma+strips
Thanks to forum member nicedayforit for this one
Post #278369 31st Aug 2014 8:29pm
iphs
England 2003 Range Rover Vogue Td6 Buckingham Blue
Have not done any mods yet, still getting used to the RR quirks and to be fair I have been busy doing things for the better half.
However the first thing for me to do is by-pass the EGR, replace the crank case breather with the BMW filter kit and change all oils and filters. Ordered the parts required yesterday. May get a remap done then but have not decided for sure.
Next on the list is to fit a new A/C compressor. Find out why I keep getting the "Trans Failsafe Prog" bong, when there appears to be nothing wrong with the transmission.
Then change the head unit as per Pete's modification.
When that lot is done I will start looking at other Mod's.
Post #278370 31st Aug 2014 8:42pm
andyleeds
Stan, can you also point me in the direction of the EGR removal thread? I have looked but can't find it Sad
Post #278400 1st Sep 2014 6:34am
its in the wiki Thumbs Up ... - .- -.
Post #278401 1st Sep 2014 6:44am
andyleeds
doh! is the changing of the transponder to get one of dave's keys working there too? Smile
Post #278405 1st Sep 2014 8:16am
probably , if not use the search function. ... - .- -.
Post #278411 1st Sep 2014 8:42am
andyleeds
yep tried that, can't find it, also put a question on the group buy section... i will pm dave....
cheers
Post #278414 1st Sep 2014 8:56am
steptoe
LPG fitted.
Standard wheels powder coated black.
Post #278462 1st Sep 2014 1:15pm
Boydonegood
United Kingdom 2004 Range Rover Vogue Td6 Ipanema Sand
Apart from the 2010 Conversion:-
Back Box sprayed Black
2010 look Satnav aerial
Titanium badges and boot strip
Tailgate window rubber removed . (cleans the back end up loads)
DLR's
Navy Blue with cream piped mats. (brighten inside up)
Really need to get round to:-
Silver spoke steering wheel
Nappa Leather steering wheel
Colour code side vents
Walnut rear panel
I want to change the number plate and interior lights to crisper LED's.. Ive searched but theres so much info. Has there ever been a complete list of best bulbs (colour and brightness) to swap out?
Cheers
Tel Accept, some days your the pigeon, some days your the statue!
Post #278767 3rd Sep 2014 7:53am
espaceboy
just add first aid boxes under each of the front seats, very handy storage for small tool, chargers, torches etc
and of course a first aid kit.
BMW boxes and brackets, just tapped a few existing holes under the seat and job done
Ricky
Post #279119 4th Sep 2014 8:54pm
Page 2 of 3 <123>
