![]() | Home > Camping, Caravanning and Holidays > Towing MPG |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2588 ![]() ![]() ![]() |
Not sure if ita any use but I get about 14.5mpg from a TD6 when towing trailer + 2 horses, around 2700kg, that's averaged over a 350 mile journey at a good average speed |
having just worked that out, my man maths are going mad now, can anyone give a real world indication of towing with an SC?? |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
When I had my LPG converted SC I used to get between 10 - 12 MPG when towing the caravan depending on motorway versus A roads etc (actual calculated miles versus litres filled) so it looks like you are similar...... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
ksmith100 Member Since: 20 Apr 2012 Location: Stirling(ish) Posts: 77 ![]() ![]() ![]() |
I managed 20mpg at one point in a 3,500 mile tour through UK, France and Germany towing a 23' van. Worst was 11mpg going up a long incline in France. Being honest with the FF being such a capable tow car I don't care about the MPG, I would rather sacrifice MPG than be stuck behind something slower. You are either at Le Mans or waiting for Le Mans
If it helps I just checked the dash computer of my 2010 5.0 S/C. Was towing at the weekend down in the Cotswolds. Twin-axle van with all the clobber. 16.8 mpg since last fill up which was just as we left so it's fairly accurate. 182 miles of which about 20 were not towing. Petrol, not LPG. |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
I used to get about 12 with the 4.4 petrol towing 2200kg, now get about 18 towing 2400kg with the 4.4 tdv8.
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
I saw over 30 on the M5 at 55mph until I hit a slight gradient. I think I averaged around 25 for the whole journey. |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
3.6 tdv8 towing 1900kg twin axle. 23.2mpg |
jon3929 Member Since: 01 Jan 2015 Location: Weston Super Mare Posts: 62 ![]() ![]() ![]() |
3.0 TD6 towing a 2000kg single axle averaged 24mpg over about 600 miles at average 55mph |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
3.6TDV8 with twin axle Brian James with 300Tdi 110 Defender with two sofas and chest of drawers. Surrey to West Wales about 250 miles averaging about 55mph and I think it was about the 26mpg mark according to the on-board. |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
The real way to calculate actual/real MPG, is not to use the onboard comp, but to reset miles after a brim fill, drive, and re-brim fill it. also, With lpg the computer will (onboard) show a false reading, as its a bit more actual fuel running into engine, than the onboard (petrol equivalent) says its metering. ( Ie petrol is denser, ) Again brim the tank, and reset the mileometer, then re-brim. Then use calculator. Miles/litres or gallon equiv. This will not be 100% as the lpg tank might not fill to brim at different temperatures, and I have noticed some lpg pumps don't 'fill to full' like others, as the pressure cuts off at different pressures, therefore you really need to fill at same pump.. (Not really practical,) -all this means that some MPG boasts on this forum are a bit, err, ahem, -WRONG!
