Home > Maintenance & Mods (L322) > vent
vent
my left hand dash vent seems to have collapsed inside ,is it just a prise off job to get to the gubbins...
Post #24489 4th Aug 2010 11:52am
Someone on here has done this and they will be along shortly to assist! Discovery 4 HSE
Post #24491 4th Aug 2010 12:08pm
thank you muchly sir...
Post #24493 4th Aug 2010 12:22pm
M44K TS
It's a bit fiddly to say the least.
From memory, I don't think you need to remove the whole side panel, look through the vent at each corner, you should see 4 square clip sections, get 2 small flat screwdrivers, I used precision ones, insert a screwdriver in opposite corners and pull the clips in, you should be able to extract the vent with just 2 clips out of the way. Don't worry if that makes no sense, once you look at the vent and see the 4 clips, you should know what I mean. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #24579 4th Aug 2010 5:46pm
Thumbs Up ..job for when it stops raining..
Post #24585 4th Aug 2010 6:07pm
done the way you said but i retracted all four clips to get the unit out easier...mended the mechanism and now it works as should..thanks .
Post #24722 5th Aug 2010 3:38pm
