Home > Maintenance & Mods (L322) > Reverse camera replacement |
davidjpowell Member Since: 11 May 2014 Location: Doncaster Posts: 106 |
The reverse camera on our FFRR died. Found this chap on da bay who,has installed an upgraded camera in the same housing. Better picture and substantially less costly then replacing with oem.
19th Aug 2014 5:55pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35379 |
£160!!!...a bit steep me thinks. ... - .- -.
19th Aug 2014 7:08pm |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2289 |
That looks very good! Mine is sometimes intermittent, so I might just try this. Did you go there or did you send your old one?
19th Aug 2014 7:36pm |
I went there as I was in the area. Took about 30 minutes.
19th Aug 2014 7:41pm |
will see if it is difficult for a non tech like me to take the old one out |
19th Aug 2014 7:45pm |
Taking it out looked pretty straightforward.
19th Aug 2014 7:59pm |
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 |
he's doing it a bit cheaper here http://www.ebay.co.uk/itm/Landrover-L322-F...4ada58e4fc |
19th Aug 2014 8:56pm |
That's apparently just a replacement camera mounted next to the existing....
19th Aug 2014 9:05pm |
Silversurfer13 Member Since: 17 May 2014 Location: London Posts: 83 |
I'm wondering if they can upgrade it to a DayNight / Infrared LED style camera??
20th Aug 2014 11:31am |
