Home > In Car Electronics (L322) > TV Tuner
steve9bug
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
TV Tuner
right my late 2004 on a 54 reg has the TV in and a touchscreen display unit but must be old analogue and will not show a picture,
Is there a straight swap I can put in like a hybrid unit that will work.
If so would this one do the job As a straight swap plug and play
PAG TV Hybrid
42631
HY
BBU4A
AW93-14F641-AG
535041 828 0216881 00 SW H9 06 04 HW D1
Post #275040 8th Aug 2014 11:56pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
I'm sure someone will be along soon to clarify but IIRC I read somewhere that the pre-facelift models with touch screens were a bit of a hodge podge of new and old parts and therefore more difficult to upgrade from analogue to digital - I may be remembering it wrong tho.
Post #275066 9th Aug 2014 10:40am
gezzer1520
United Kingdom 2005 Range Rover Vogue Td6 Java Black
Hi, I have a 54 plate Vogue, with touch screen and the fibre optic connections between satnav, radio etc. I have just fitted a digital PAG Hybrid tuner, sourced from ebay. Well the good news is that it is a straight swap, and it works, but it doesn't tune properly.You set the country to UK, and it should tune all the available digital channels, but only one comes up. Neither manual nor automatic tuning will find any other channels, and it is always the same channel that comes up if UK is selected. Oddly, if you change the country setting to a different country, it will again find one channel, but a different one for each country. It is weird, I think it is a software glitch, as you can change channels by changing country, although it takes about 20 seconds each time. Can't be the aerial, or it wouldn't find other channels when settings changed. Very strange, but otherwise works well. Anyone got any ideas??
Post #275640 13th Aug 2014 2:42pm
Discotigger
Guys,
There's been plenty of threads on the correct hybrid tuners to get,
The ones you need for our FF's (touchscreen sat navs) are the ones with the following code:
AH42 19C063 ... and the last two letters should be from AA onwards.
Any other code types will probably not work properly in the UK as they could well be Japanese/Asian/Foreign specification units.
My Hybrid PAG TV Unit has the code AH42 19C063 AH, it came from a 2010 RRS and was plug and play into my FF.
Hope this helps.
Post #275666 13th Aug 2014 4:32pm
gezzer1520
Hi Discotigger, Yes, the one I have is the Japanese spec unit. Unfortunately, I did not do my homework properly, having joined fullfatrr after buying the tuner instead of before. They do get a picture and sound perfectly, but refuse to tune ether channels. I was hoping someone like Wiggs might have worked out if they are possible to convert or modify. They look physically identical, so it's probably just a parameter or software incompatibility.
Post #275823 14th Aug 2014 6:29pm
Discotigger
Sorry to hear that Gezzer1520, try giving Wiggs a PM on this site on the matter.
Don't know if they can be reflashed, as the chips may be non-reprogrammable.
Unfortunately, if Wiggs can't help then the only course is to bite the bullet, or get one of the ones I listed above. Big Cry
Post #275826 14th Aug 2014 6:45pm
gezzer1520
Good idea. I know where there are a few of the Japanese versions available at a good price, so if there is a way of modifying them, it may be of interest to him. Fingers crossed.
Post #275837 14th Aug 2014 8:21pm
quabba
Scotland 2005 Range Rover Autobiography 4.4 V8 Java Black
Hi mate, did you get a reply to this
Post #279663 7th Sep 2014 10:37pm
If anyone needs a hybrid tuner we have some available Thumbs Up
PM me if of interest Thumbs Up
Post #279668 8th Sep 2014 12:14am
gezzer1520
Hi quabba, I did get a reply from Wiggs. He is going to experiment when he gets a chance. I think it's actually a new UK unit rather than a Japanese spec. It is the software version that is incompatible, but Wiggs said it might be possible to modify.
Post #279763 8th Sep 2014 7:15pm
quabba
Hi gezzer, what part number is yours if you don't mind me asking?
Post #279895 9th Sep 2014 11:38am
cowman
United Kingdom 2005 Range Rover Vogue SE Td6 Adriatic Blue
i have just brought a hybred one for my 2005 td6 touchscreen from main dealer for 200 pounds brand new ,bargain i think.
Post #280336 11th Sep 2014 9:19am
good price that, if it fits and works ,can you post the part number here please.. ... - .- -.
Post #280337 11th Sep 2014 9:20am
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
cowman
have they got any more?
Post #280386 11th Sep 2014 1:44pm
cowman
landrover part number is lro24779 and the number on the label is AH 4219C063-AE ,i just unpacked it brand new in original box,i will have to wait until the weekend to fit it as i have lent my rangie to my son and he is in scotland at the moment,i dont have any more.
Post #280457 11th Sep 2014 8:01pm
