![]() | Home > In Car Electronics (L322) > TV Tuner |
cowman Member Since: 24 Jul 2013 Location: United Kingdom Posts: 186 ![]() ![]() ![]() |
fitted it and it works perfect. |
yes it was a bargain ,it was brought off the net and i got a invoice with it . |
gezzer1520 Member Since: 13 Aug 2014 Location: Liverpool Posts: 6 ![]() ![]() ![]() |
Sorry for the delay in getting back to you. The one I have (which works but not able to change channels) is AW93-14F641-AG |
rrsport123 Member Since: 07 Oct 2014 Location: sheffield Posts: 1 ![]() ![]() |
Hi gezzer, I may have a deal on the same tuner you have fitted did wigs have to modify the unit? do you get many channels? cheers mate |
Hi, I think it gets about 6 different channels, but to change channel you have to go into the setup and change the country and type then do an autoscan, and it will just show one channel. I haven't tried all the possible permutations of country and type (pal, ntsc, secam etc) Each one I have tried brings up a channel, bit not always different. I will have another play and see if I can figure out if there is any logic to it. |
