![]() | Home > Wheels & Tyres > sport wheels on vogue |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7860 ![]() ![]() ![]() |
They will fit, but the wheels will have 275 tyres on with a lower profile, that's of course if you have rrs tyres with them.
Capers Member Since: 07 Jan 2013 Location: manchester Posts: 14 ![]() ![]() ![]() |
thanks for that is a lower profile tyre a bad thing? |
Well the overall circumference will be less so the speedo will be a bit out, as the car won't go as far per wheel revolution.
many thanks for that you are indeed a knowledgable chap if that's how you spell it |
Your are most welcome. If you have all the info, you can then make an informed decision, as you see fit.
you have a pm sir |
allycraven Member Since: 28 Mar 2011 Location: North Craigo, Angus Posts: 440 ![]() ![]() |
yes they will....
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
295/45/20 on my old FF,
many thanks for that they look good.
I think you could but I think all that matters is that the wheel and tyre meeting the load requirements as a minimum as in 109 on tyres not sure what whhel load weighting is I know on disco3 it was about 980 kg per corner.Some of the replica wheels certainily do not meet the load rating and therefore won't be suitable |
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 315 ![]() ![]() ![]() |
Good read above
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7969 ![]() ![]() ![]() |
YES - assuming you want valid insurance. Any undeclared modification would give them room to wriggle out of a claim. If its different to the build sheet of the car, then declare it. I just put alloy wheels - additional value zero and with most companies it doesn't affect the premium, but is stated on the policy so I'm covered ![]() |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16312 ![]() ![]() ![]() |
RRS use narrower 19” wheels then the 20” wheels so the 19” wheels use the same size tyres as the FF ![]() |
Top man thanks Craig.
