Home > Wheels & Tyres > sport wheels on vogue
Capers
United Kingdom 2006 Range Rover SE 4.2 SC V8 Java Black
could anybody tell me if twenty inch 2007 sport wheels will go straight on to a 2008 vogue or do I need bigger nuts or something?
many thanks
Post #274971 8th Aug 2014 4:21pm
mjdronfield
They will fit, but the wheels will have 275 tyres on with a lower profile, that's of course if you have rrs tyres with them.
They will be 9J width not 8.5J which is a stretch for the standard fit 255 ff tyres.
But to answer your question, the nuts should be the same on a 2005 plus ff.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #274973 8th Aug 2014 4:31pm
Capers
thanks for that is a lower profile tyre a bad thing?
Post #274974 8th Aug 2014 4:34pm
mjdronfield
Well the overall circumference will be less so the speedo will be a bit out, as the car won't go as far per wheel revolution.
It's not a million miles off, as the aspect ratio is a % so 275/45 which is the rrs size has a sidewall height of 45% of 275mm. Whereas standard ff size is 255 / 50 so 50% of 255 mm, times 2 as there are 2 sides to the tyre added to alloy dia is the diameter.
There are web sites that can calculate everything for you.
The main worry is that the car is not type approved with those wheels and tyres, so irrespective of the whys and wherefores, your insurance will not be valid unless you agree it with them.
Plenty have them fitted though.
You will find a 295 by something tyre is actually closer to the standard ff size for overall rolling circumference. Just depends what your personal take is on it. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #274976 8th Aug 2014 4:46pm
Capers
many thanks for that you are indeed a knowledgable chap if that's how you spell it Smile
Post #275006 8th Aug 2014 7:31pm
mjdronfield
Your are most welcome. If you have all the info, you can then make an informed decision, as you see fit.
If you were not sure, the issue is the width of the alloys, as 9J is 9 inch wide at the rim, a 8.5J is obviously half an inch narrower and the standard 255 tyre is not really wide enough to seat on the alloy rim properly on a 9 inch wide alloy, hence a wider tyre being needed.
The alloys sit a bit further out if you fit an rrs alloy, that's the offset from the hub. The ff does seem to have a more purposefull stance.
Have you got some to put on ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #275007 8th Aug 2014 7:43pm
Capers
you have a pm sir Thumbs Up
Post #275011 8th Aug 2014 8:00pm
allycraven
yes they will....
that said, the 275/45's struggle to fill the arches so some members have gone with 295/45 on the same rim which look better... '08 Audi S6 Avant 5.2 V10 with Milltek non-resonated. Vrrrrrrmmmmmph
'59 Ford Kuga Diesel (boring but AWD and 40mpg...)
2007 (07) Subaru Forester XTen 2.5 Turbo. (Roundabouts are fun again!)
2007 (07) 4.4 V8 Vogue (gone)
Post #275018 8th Aug 2014 8:23pm
295/45/20 on my old FF,
Post #275021 8th Aug 2014 8:28pm
Capers
many thanks for that they look good.
Would I have to inform my insurance company if I fitted them?
Post #275025 8th Aug 2014 8:53pm
Googsy
I think you could but I think all that matters is that the wheel and tyre meeting the load requirements as a minimum as in 109 on tyres not sure what whhel load weighting is I know on disco3 it was about 980 kg per corner.Some of the replica wheels certainily do not meet the load rating and therefore won't be suitable Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #275026 8th Aug 2014 8:58pm
Pvw10
United Kingdom 2014 Range Rover Vogue SE SDV8 Firenze Red
Good read above
I fancy a set of style 5 RR Sport rims for my L322, they are mint and genuine rr plus my insurance says no premium hike 👌
Interestingly they have the correct size tyres fitted is 255/55/19 so just to protect myself are these a straight swap ? Many thanks
Paul
Post #379783 28th Mar 2016 3:22pm
YES - assuming you want valid insurance.
Any undeclared modification would give them room to wriggle out of a claim. If its different to the build sheet of the car, then declare it.
I just put alloy wheels - additional value zero and with most companies it doesn't affect the premium, but is stated on the policy so I'm covered Thumbs Up
Post #379795 28th Mar 2016 4:25pm
Pvw10 wrote:
Good read above
RRS use narrower 19” wheels then the 20” wheels so the 19” wheels use the same size tyres as the FF Thumbs Up
Post #379798 28th Mar 2016 4:32pm
Pvw10
Top man thanks Craig.
Are they a straight swap with the same nuts though ? Many thanks
Paul
Post #379799 28th Mar 2016 4:34pm
