![]() | Home > Maintenance & Mods (L322) > Squeak or Tweet causes? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35651 ![]() ![]() |
i have a solution , well its my wife's really and this is what she does.....any unusual sound emanating from the car is solved by winding the windows up and turning up the radio. |
Well Stan, my wife never noticed it, clearly proving your [air con] on, windows up and music blasting theory |
i've noticed on mine that since fitting the new brembos on the front that there's a slight grind on stopping and i've put that down to the hot weather and the brake bits being new...
No grind on ours at all Stan just the wheelbarrow squeak I mention... It's driving me nuts and I'm sure there's a correlation with front passenger side wheel and slight left steering turns... Apart from the brake pads and caliper pistons, what else can I grease? ... Apart from the dealer's palm |
thinking aloud here, how about jacking the whole front up ,switch on the engine whilst in park and handbrake on and turning the steering wheel..there wont be any 'weight' on the parts but you might hear something.. ... - .- -.
It's an idea Stan... I'm sure Mrs pld would gladly to volunteer to operate the controls provided I'm standing right in front of the stands and the car! |
Just found this interesting description on ehow when typing in symptoms of a noisy wheel bearing:
In answer to Stan's question, I drove the car in the wet today and no squeaks! |
a dry bush maybe [waits for puns |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6768 ![]() ![]() ![]() |
^ See my previous post re. upgrades! |
http://www.fullfatrr.com/forum/topic26929.html Got - 2017 SDV8 Autobiography in Loire Blue
Hoping to remove the front passenger wheel today so as to visibly check the condition of the bushes, then grease them and also grease the suspension arms.
