Home > Maintenance & Mods (L322) > Squeak or Tweet causes?
pld118
Hi,
I've doubtless bored everyone with previously posted tales of brake squeal and causes/ solutions but... The similar sounding noise has returned from the front end of the car and it does appear associated to wheel revolution.
It's not happening under braking and seems to come on intermittently when the car is travelling between 30 & 40 mph, mostly in a straight line. I wondered if it was happening over bumps or ruts, but it's not and I wondered if it was more prone to occur during left steer action. It occasionally comes on under left steer although it happens more so in a straight line.
The noise only comes on for a second or so before stopping and will stop sooner if I dab the brakes. I'm also sure it happens more when the car is cold and is just at the start of a journey.
I'm also sure there is an oscillating, very low tinny, whirly flutter sound emanating from the direction of the brake shields and which can be heard when the car is being driven with the windows down.
The squeak noise I refer to does sound very much like birds tweeting in the trees... It's not the birds in the trees though!
Yes, I could just take it to a garage but knowing my luck, it won't replicate so I'd rather investigate myself for now.
Could it be a wheel baring, a joint, something suspension related or are the Brembo brake calipers the most obvious source... in your opinion?
Thanks in advance Thumbs Up
Post #274788 7th Aug 2014 10:33am
i have a solution , well its my wife's really and this is what she does.....any unusual sound emanating from the car is solved by winding the windows up and turning up the radio. Mr. Green
seriously it sounds like something is to dry like a bush or similar..does it do the same when driving in the wet ryan? ... - .- -.
Post #274799 7th Aug 2014 12:28pm
pld118
Well Stan, my wife never noticed it, clearly proving your [air con] on, windows up and music blasting theory Laughing
Before I regreased the brakes several weeks ago it did it in all weather but I think it's only in the dry I've noticed the noise over the past few days Stan... but I could be wrong and by all accounts, in the coming days, the car will see some wet weather!
Post #274809 7th Aug 2014 1:05pm
i've noticed on mine that since fitting the new brembos on the front that there's a slight grind on stopping and i've put that down to the hot weather and the brake bits being new...
i suspect that once the typical british weather comes and the brakes become a bit worn , the 'noise's' will dis-appear.. ... - .- -.
Post #274811 7th Aug 2014 1:12pm
pld118
No grind on ours at all Stan just the wheelbarrow squeak I mention... It's driving me nuts and I'm sure there's a correlation with front passenger side wheel and slight left steering turns... Apart from the brake pads and caliper pistons, what else can I grease? ... Apart from the dealer's palm Laughing
Post #274815 7th Aug 2014 2:51pm
thinking aloud here, how about jacking the whole front up ,switch on the engine whilst in park and handbrake on and turning the steering wheel..there wont be any 'weight' on the parts but you might hear something.. ... - .- -.
Post #274836 7th Aug 2014 5:56pm
pld118
It's an idea Stan... I'm sure Mrs pld would gladly to volunteer to operate the controls provided I'm standing right in front of the stands and the car! Shocked
Post #274871 7th Aug 2014 9:13pm
pld118
Just found this interesting description on ehow when typing in symptoms of a noisy wheel bearing:
"Noise
The most common symptom of a front wheel bearing problem is noise coming from the front tires. The wheels will emit a high-pitched squeak or a rumbling sound, especially during sharp turns. The noise may become louder during acceleration or deceleration, and it may disappear completely when the vehicle is riding at a steady speed. Also, the noise may worsen when the brakes are applied."
Question
Post #274924 8th Aug 2014 7:26am
pld118
In answer to Stan's question, I drove the car in the wet today and no squeaks!
Post #275181 10th Aug 2014 2:49pm
a dry bush maybe [waits for puns Mr. Green ] ... - .- -.
Post #275182 10th Aug 2014 3:13pm
^ See my previous post re. upgrades! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #275184 10th Aug 2014 3:28pm
Question ... - .- -.
Post #275188 10th Aug 2014 3:44pm
http://www.fullfatrr.com/forum/topic26929.html Got - 2017 SDV8 Autobiography in Loire Blue
Post #275191 10th Aug 2014 3:55pm
pld118
Off Topic
Post #275197 10th Aug 2014 4:33pm
pld118
Hoping to remove the front passenger wheel today so as to visibly check the condition of the bushes, then grease them and also grease the suspension arms.
If greasing the bushes/ suspension arms is there any special equipment/ process required and will Comma CV Lith-Moly Grease or Comma Copper Ease (grease) do?
Any how to tips greatly appreciated.
Thanks in anticipation Thumbs Up
Post #275758 14th Aug 2014 12:51pm
