Home > Technical (L322) > Speedo Issue |
What's telling you you're doing 5mph less than you think it is doing? |
3rd Aug 2014 7:57pm |
Flunter Member Since: 27 Apr 2014 Location: East Yorkshire Posts: 26 |
Erm, the speedometer display. Not Representative! |
3rd Aug 2014 7:58pm |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
@ Pld...was thinking the same ..
3rd Aug 2014 8:06pm |
If the speedo display displays 30mph, how do you know it's only doing 25? |
3rd Aug 2014 8:07pm |
As I stated in my initial post, I've checked the speed by following other vehicles. When they're doing 30 my speedo shows 25, and the same at other speeds. I checked it against 3 different cars with the same results. Not Representative! |
3rd Aug 2014 8:08pm |
Ah...understand now...the wiki has a workshop manual and you may get a clue there, but obvoius stuff like tyre wear will make a difference. GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
3rd Aug 2014 8:10pm |
Wasn't clear to me in the OP. Sorry.
3rd Aug 2014 8:34pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
Whilst I find your methodology in determining your vehicles actual speed somewhat dubious, can I suggest in the first instance that you have the car plugged into a diagnostic unit to check if any faults are logged on the ABS system. |
3rd Aug 2014 8:45pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35286 |
first port of call would be to buy or borrow a stand alone sat nav and compare your speed to that.... ... - .- -.
3rd Aug 2014 9:00pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
I agree with Stan. So many phones have gps, it should be easy to get a passenger to test to for you at a variety of different speeds.
3rd Aug 2014 9:45pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
You say you have standard tyres... What size are they? Previously..
3rd Aug 2014 10:18pm |
Alex Millar Member Since: 05 Jun 2015 Location: Glasgow and Arran Posts: 24 |
I have the same issue. Checked by using another satnav and speed display signs on roadside and roughly 20% below actual speed is being registered on speedo. Not sure how to correct it or just live with it |
12th Sep 2015 8:20am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1753 |
The speed display signs are not particularly accurate... |
12th Sep 2015 10:11am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Like most people my speedo over reads by a tad ( normal ) but if I set a speed warning bong it goes off right on the money , have you checked that ? 2008 MY Supercharged
12th Sep 2015 10:12am |
